thermal arc 185
发表于 2021-8-31 22:38:31 | 显示全部楼层 |阅读模式
Hey im looking at a thermal arc 185 with some tig accesories its about 6 years old with little use, Im wondering whats a good price on this welder??? thanks, Matt
Reply:The new model is the 186 now right? Welders that are essentially new seem to go for essentially new prices minus a little discount to make it worth buying it. If a new 186 package is $1800 off cyberweld then I would think anything less than $1500 is a good price as long as it works 100%.  Take a little more off for dings and dents.  Don't buy it if everything doesn't function 100%.  Warranty is a bargaining chip, so you can use that to further hammer the price. Don't forget to cost-out accessories, filler rod, extra tig torch parts, that stuff seems to add up quickly Also don't forget it's not a Miller and there is a bigger hit on non-USA made stuff on resale. At half price and full function it's a no brainer.  I searched ebay and craigslist for a while and never came close to that.Last edited by bikesandcars; 12-18-2013 at 12:34 PM.
Reply:I look at used stuff as a gamble since no warranty. Half price is my number in general. Or less depending on condition and age.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:TA 185TSW with cart, foot pedal and regulator, $900.http://easternshore.craigslist.org/tls/4245312098.html"USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:^ that's the one I'm looking at. Does it seem like a good deal? Sent from my iPhone using Tapatalk
Reply:The later TA Arcmaster 185 is somewhat more desirable, I understand.  Note that the location of this one is on an island in the Chesapeake bay.  If it's been there all its life, be on the lookout for internal corrosion."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Ok thanks exactly what I needed to know. Would this be a good welder to learn tig on? I have only tig welded about an hours worth over 5 years ago. Sent from my iPhone using Tapatalk
Reply:Originally Posted by Gsxr600Would this be a good welder to learn tig on? I have only tig welded about an hours worth over 5 years ago. Sent from my iPhone using Tapatalk
Reply:Good machines. Offer $800 and see what he says.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Good machine for the price have him demo the operation for you check out the manual. http://victortechnologies.com/IM_Upl...430429_503.pdfI have the Arc-master version works great although I have never done any stick welding with the thing. My only regret is that I did not get the Arc-master 300.
Reply:If I was in that area I would scoop it up ASAP. Quality machine. As far as I have heard the Japanese built Thermal Arc 185's are very reliable and functional. Where as the new 186's have junk foot control pedals from the factory.Local 83
Reply:Jump on that ASAP.   That's a great price.  The TSW were Jap made.  Very durable reliable machines that are built better than the newer 186 versions.  It only lacks the 5 program memory feature that the new one has.  I have the newer 300 and never use the memory feature as every thing I weld tends to be different and it's fun and a learning experience to play with the parameters.  Apparently, the arc focus is greater than Millers, so 150 Hz AC on that machine is equivalent to millers 200-250 HZ in terms of cone size.  I had that machine and a Blue lightning Dynasty before I found my 300.  It's every bit as good as a Dynasty, but less bells and whistles.  If it works fine, JUMP ON IT FAST!TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
GMT+8, 2025-12-30 17:21 , Processed in 0.073172 second(s), 18 queries .
