Making 6011 look good is my next challenge
发表于 2021-8-31 22:38:31 | 显示全部楼层 |阅读模式
I own top quality machines for all four welding processes, but I find myself migrating back to stick. Recently I bought a Miller Bobcat 250 machine for a back up generator for my house, while also having a nice outdoor welder. Very happy with it's performance. I find it easy to blame the type of rod for the lack of beauty , but I'm determined to work on that skill until I get it right. This weld was using a 1/8 6011 rod at around 130 amps. Attached ImagesMiller Bobcat 250Syncrowave  200Millermatic 252Spoolmatic 30ASpectrum 625 X-TremeMaxstar 150SVictor O/A torchesDewalt angle grindersWelded on/off for over 40 years.
Reply:Gotta make your beads longer than a inch bud. Did you use the stubs off my floor by any chance?I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Originally Posted by weldermikeGotta make your beads longer than a inch bud. Did you use the stubs off my floor by any chance?
Reply:130 amps is a bit high on 1/8" 6011, even if you were running on AC. Typically you are looking at suggested amp settings of between 60-70 on the low end and 110-120 on the high end.I've seen a few rare people who can make really nice 6010/11 beads. Beads that can come really close to looking like 7018 can. Those look pretty good for the average  user. If you can tighten up your ripples they'd be outstanding..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Ok, I'll work on those ripples and turn the amps down a little. The beads were 3" long. Thanks for the quick response.Miller Bobcat 250Syncrowave  200Millermatic 252Spoolmatic 30ASpectrum 625 X-TremeMaxstar 150SVictor O/A torchesDewalt angle grindersWelded on/off for over 40 years.
Reply:Far as 6011 goes, I've had the best luck with Hobart's 335A. I've run 60xx just like I would 7018, I don't think it came out to bad. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Cep, is the 335A, andor 335C for that matter, worth the effort to source?  I use 6011 at work a lot and have just been using the Fleetweld 180 due to ease of finding it.  The old white Murex or Harris (IIRC) were phenomenal.  I found a half open box on the back of pallet recently in my shop. Probably there for at least 10 years and I totally forgotten how nice they ran. The regular Hobart(Selectrode) sucks!Last edited by kald; 12-16-2013 at 09:15 PM.
Reply:I don't know anything about the 335C, but the 335A is childs play to run. Someone told me it has arc stabilizer in the flux to make it easier to run on AC. Here is a 5-G 4-inch pipe I did with 335A. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:I've been wanting to try 335c but don't want to "try" 50lbs of it. Edit: Nice beads by the way Cep and Gobysky.
Reply:I found a half open box on the back of pallet recently in my shop.
Reply:Gobysky, another thing that might help you! While welding play with the arc length, get closer, and farther away. Remember the results! Closer is a cooler puddle, more fill. Father away is a hotter puddle for cutting your way in. I find myself changing the arc length for each ripple. Give it a try, and see what you think. Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:I'll try that CEP. Thanks.Miller Bobcat 250Syncrowave  200Millermatic 252Spoolmatic 30ASpectrum 625 X-TremeMaxstar 150SVictor O/A torchesDewalt angle grindersWelded on/off for over 40 years.
GMT+8, 2025-12-30 17:23 , Processed in 0.101106 second(s), 18 queries .
