Looking for a TIG
发表于 2021-8-31 22:38:29 | 显示全部楼层 |阅读模式
So basically I'm looking for a good TIG welder. I'm assuming most of you will say Miller's Dynasty. I'm not partial to any brand name (as long as it's a good one!). Something that will preferably run off a 50amp circuit, that's relatively portable and small, and will give me the best bang for my buck. I'll be welding everything with it. The thicker aluminum I can do with my MIG but it would be nice to be able to weld 1/4" aluminum. I know there's also the Thermal Dynamics machines, Lincoln TIG's, and I've seen some recommend the HTP machines. I don't think I've ever heard anything about the Hobart TIG's, are they any good? I have a $6000 budget for shop improvement so I'd like to be in the $2000-$3000 range for the TIG. I'm not opposed to buying used either.John 3:16(2) Miller Pheonix 456(2) Millermertic 252Dynasty 210DXHobart 210MVPDoringer D350 SA Cold SawScotchman 350LT Cold SawWebb 10x50 MillWebb 15x40 LatheGeka Bendicrop Ironworker
Reply:Dynasty would be my 1st choice given the parameters you have listed. The Thermal Arc 186 isn't a bad choice either, but I'd give the nod to the Dynasty on output and options.Portability sort of rules out the Syncrowaves, but if you didn't need a portable machine a Syncrowave 250 would be ideal, and the Syncrowave 210 might also fit your bill..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:I have this one for salehttp://www.ebay.com/itm/Lincoln-Squa...item20dcfdd82bCenterLine Motorsports - http://www.facebook.com/pages/Center...89516977767905
Reply:if you're looking to be able to weld 1/4" with little concern for exceeding duty cycle, you're looking at a pretty much non-portable machine, as it will need to be able to do 250+A at relatively high duty cycles. 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:50 amp circuit is going to rule our the transformer machines at full power.  They pretty much need 100 amp service.  That'll run a HTP 221/Dynasty 200/Lincoln 205 just fine.  S/F....Ken M
Reply:Talk to this guyhttp://weldingweb.com/vbb/showthread.php...ster-300-ac-dcThink he's decided to keep it, but it's a great unit for everything.  Less bells than a Dynasty, but a solid performer. Most made in Japan (as mine is) and you know their record with manufacturing and electronics.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:The Lincoln PT 225 tranny will run on a 50 amp 230v circuit. Excellent ac/dc tig machine and very good stick welder too. Right in your budget.Last edited by snoeproe; 12-23-2013 at 10:32 AM.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Originally Posted by snoeproeThe Lincoln PT 225 tranny will run on a 50 amp 230v circuit. Excellent ac/dc tig machine and very good stick welder too. Right in your budget.
GMT+8, 2025-12-30 17:21 , Processed in 0.235065 second(s), 18 queries .
