welding table for work II
发表于 2021-8-31 22:38:28 | 显示全部楼层 |阅读模式
Well after the last banana boat bonanza I figured I would start over from scratch.  The tubing is 3in 3/16 wall with some heavy duty expanded metal I found laying up against a storage building. Haven't got the top on yet. Im holding out for a bit because I heard there might be some 1/2 plate I could scratch up from another department.
Reply:looks damm sturdy!
Reply:Nice table, there is no such thing as overkill.TOO MANY TOOLS & NO MORE SPACE
Reply:Haha, that last one you made was funny! This looks better.
Reply:nice frame you got there. looks real heavy duty.i.u.o.e. # 15queens, ny and sunny fla
Reply:Great looking table.  Did you get the 1/2 inch plate
Reply:No go on the 1/2 inch plate. So I had to use an 18 inch wide X 8 foot piece of scrap 1/4 that had been laying in the weather for a few years with very rough torch cuts.after a few hours of grinding this is what it turned out to be. Good enough I guess. Its a heck of a lot better than the wood work bench
Reply:No pretty polished top. Just hit it with a cup brush and called it good. I was more worried about straightening out Michael J Fox's torch cuts. Got a two inch gap for clamping and a couple inches of overhang. All welding was done with a pos lincoln ac only Briggs powered welder with 1/8 6011.
Reply:That will make you a good work bench.  I have a table that I was given that needs a lot of work.  But it was free.  I will post when I can dig it out of the barn this spring
Reply:Originally Posted by tackitVery nice job on your table.        http://www.ebay.com/itm/4-Large-All-...-/171213854019
Reply:Thanks. I figure it will pretty much finish itself up just from grinding off spatter and stuff. No sense in making it shiny.
GMT+8, 2025-12-30 17:23 , Processed in 0.100093 second(s), 18 queries .
