type of aluminum to use
发表于 2021-8-31 22:38:27 | 显示全部楼层 |阅读模式
I am planning a meat trailer build and the local supplier has 5052 & 5086 available. I had originally planned on using 6061 but it isn't available in 1/8". Which material is better suited for a small trailer bucket?  will either weld alright with 4043?
Reply:Maybe this will helphttp://www.metalsailboats.com/MATERI...SELECTION.htmlEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:good reference, thank you. I intend to have sheets bent to form this and minimize the welding
Reply:best option 5052 material and weld with 5356Option two 5052 material and weld with 4043Option three, pick from the two above6061 does not bend very well.
GMT+8, 2025-12-30 17:23 , Processed in 0.071638 second(s), 18 queries .
