Super Skyscraper: The Leadenhall Building
发表于 2021-8-31 22:38:26 | 显示全部楼层 |阅读模式
On a break from watching Olympics downhill and the wild runs of curling, turned on PBS a minute ago.  A special feature on the design/build of the 41-story skyscraper The Leadenhall Building in London.  Very cool.  Massive tapered steel exoskeleton, prefabbed concrete floors, welding, black glass, granite, and 3D CAD models.  The just-in-time delivery of pre-assembled building components, non-traditional "erector set" architecture/fabrication style, and "early-in" business occupancy on completed floors is breaking new ground in high rise construction.  Impressive.  BOD is planned for mid-2014.Check it out on PBS.  Back to the show!www.theleadenhallbuilding.comLast edited by ManoKai; 02-12-2014 at 10:31 PM."Discovery is to see what everybody else has seen, and to think what nobody else has thought" - Albert Szent-Gyorgyi
Reply:Personaly,I love PBS. There "how to" shows are exactly that. No drama, no filler. Good stuff!
Reply:My problem with this is architects and engineers will see this and wonder why we cant do that with their 30,000 Sq Ft. tilt up building.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:That was a good show. Before that, they aired a doc about the domed cathedral in Florence Italy. It was mainly about how the architect found a certain way to stack the brick on the dome part so it wont cave in on itself without the help of any framework to hold it up.  Sent from my iPhone using TapatalkLincoln Pro Mig 180HF Stick/Tig Inverter WelderLincoln AC225s
Reply:@ Spicy'ahi' - saw that special also.  The famed architect Brunelleschi and his watershed herringbone style brick pattern.  Ingenious.  PBS is awesome!"Discovery is to see what everybody else has seen, and to think what nobody else has thought" - Albert Szent-Gyorgyi
GMT+8, 2025-12-30 17:24 , Processed in 0.100246 second(s), 18 queries .
