vantage 300 service
发表于 2021-8-31 22:38:26 | 显示全部楼层 |阅读模式
I am looking to buy a vantage 300. I am wondering if the oil dipstick, oil filter and the oil filler cap are all on the same side. My 305 d is not and it took a bit of planning to build a skid for it to make oil changing not real time consuming. Thank you.
Reply:Yes they are all on the same side. Very easy machine to service. Fuel and air filters are also on the same side. Great machine. I really like using mine.
Reply:They are nice to service. I have two, they are very nice all around machines. Do yourself a favor and see if you can loosen the oil filter as soon as you get the machine. Some of them are stupid tight and the fitting will break.Constant Current Weldor.
Reply:open the sliding door on the side. You will find everything you need right there- Christian M.C3 Welding & Fabrication - CNC Plasma Cutting-Mobile Welding-Custom welding and fabwww.c3welding.com
Reply:would you buy a lincoln Vantage again ? Thanks
GMT+8, 2025-12-30 17:24 , Processed in 0.083618 second(s), 18 queries .
