Schramm Air Compressor.
发表于 2021-8-31 22:38:22 | 显示全部楼层 |阅读模式
In the process of digging it out at the shop. It had 10 years of scaffolding leaning on it. Any body have any info on them? I know Kolot has one from a recent posting. Fix or sell? Attached Images
Reply:I am sure it runs, The guy I got the shop from kept everything in tip top shape before he stopped using everything.
Reply:I thought about selling mine , but probably couldn't get much for it being as old as it is, Mine was running but needed some TLC. I put it in the garage and now when I hit the button, nothing, even when I put the jump pack on it. Will need some attention , Problem is time, when i get to it I will get it up and running again. Probably use it till it dies, that could be a short or long time, it's lasted nearly 60 years, what's another 10.  I did find a guy on the antique tractor formums that had manuals but I didn't purchase one yet. they were around 40 bucks but don't know how entailed they are. There is very little on the net on these, but many models were made, some quite large. It did put out pretty good air when it was running.I see your air cleaner is missing, mine is damaged and should be replaced as well. Keep us posted."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:Originally Posted by kolotI thought about selling mine , but probably couldn't get much for it being as old as it is, Mine was running but needed some TLC. I put it in the garage and now when I hit the button, nothing, even when I put the jump pack on it. Will need some attention , Problem is time, when i get to it I will get it up and running again. Probably use it till it dies, that could be a short or long time, it's lasted nearly 60 years, what's another 10.  I did find a guy on the antique tractor formums that had manuals but I didn't purchase one yet. they were around 40 bucks but don't know how entailed they are. There is very little on the net on these, but many models were made, some quite large. It did put out pretty good air when it was running.I see your air cleaner is missing, mine is damaged and should be replaced as well. Keep us posted.
Reply:My guess is that is going to put out pretty good air. Then there is the "I got one and you don't" factor.Hmmmmm, I think I'd keep it till someone really, REALLY wanted it.Matt
GMT+8, 2025-12-30 15:35 , Processed in 0.094381 second(s), 18 queries .
