Bulk cutting wheels
发表于 2021-8-31 22:38:19 | 显示全部楼层 |阅读模式
Anyone have a source for purchasing 4.5" cutting wheels for angle grinders in bulk? I always feel like Im running out of these at the worst time. I have been buying them at the local Home depot and Lowes but Id like to just get a huge box at once and be done with it.Thanks!
Reply:Has anyone tried this brand: http://www.heleta.com/abrasive-produ...-p6463573.html$.66 each seems really cheap.
Reply:Never tried them- order some up and see how they work and let us know!    I think that's even cheaper than Harbor Freight.  the HF ones suck pretty bad, but they work good enough since I don't use them that much now that I have my porta band.Millermatic 135Syncrowave 250
Reply:I have been trying out pretty much all the different cut off wheels I can get my hands on lately.  The thing I have noticed is that the 'el cheapo' ones are el cheapo for a reason... they dont last for long at all.I have used the home depot brand (Norton) and they work, but they get chewed up so fast its ridiculous.  I had to cut a 4' long by 1.5' hole in some thin (probably 16ga or 18ga) sheet metal to install a light in a new spray booth.  One 4' cut used up an entire wheel.For comparison, I picked up some Bosch cut off wheels, and had to cut 3' of 3/16" steel and when I was done with the cut only about 1/4" of the bosch wheel had been eaten up.I have also used the DeWalt and Hilti ones and they seem to last about 3 times as long and are less than twice the price of the cheapo ones.I know you can buy a "case" of cut off wheels from Fastenal, but I have not used the ones that come in bulk so I cant say whether or not they work well.  They have 25 packs from Norton Abrasives (which may be the same at the Norton ones at HD but in my experience home depot buys the bottom of the line in whatever they sell) for $90-100 and a 50 pack from United Abrasives for $155.http://www.fastenal.com/web/search/p...iZjuevtg&Nty=0  Also if you have a store near you and get an account for your company or just a personal one they will usually give you 10-15% off the price.Last edited by ggarner; 07-19-2010 at 01:51 PM.
Reply:i  really like the makita grind wheels they seem to last longer than anything i tried so far  and  forney makes sum pretty good cutoff wheels we have a tools and more store here in wahpeton and they have the cheap wheels and cutoff disks and they dont last long for .75  compared to a 1.19 makita and forney on salemiller maxstar 150   hobart handler 210 w mig conversion hobart 250 arc force plasma cutter    boston ind cutting torch miller performance auto darkening helmet milwalkee 14in chop saw 10,000 watt generator huge drill press and industrial band saw
Reply:I can't help you with buying them in bulk, but I switched to a grinder that can use a 6" cutting wheel.  The places I buy them at have the 6" for the same price as the 4.5" but a 6" will last a whole lot longer.Miller 250x & Lincoln V205-TSmith Oxy-Prop torch
Reply:Go to a Fastenal store and buy a box of Metabo cut off wheels.  Pricy but worth it.  They last forever, cut well, and I've never had one shatter or break even when I've bound them up tight.http://www.fastenal.com/web/products...0211842&ucst=t
Reply:I order all mine from lehigh Valley abrasives.  Good prices and good service.http://www.lehighvalleyabrasives.com/servlet/StoreFrontThere is no failure...only feedback
Reply:Lehigh Valley abrasives for me as well.
Reply:Klingspor. Good prices, quality products.http://www.klingspor.com/default.htmBrian LeonardAppalachian Ironworks L.L.C.434 Long Branch Rd, Marshall, NC 28753828 649 9966828 702 [email protected]
Reply:CGW products are top of the line.  I personally have been through well over a hundred of their 5" .040 wheels and never had one break or shatter even when they catch and bind the grinder up.Have we all gone mad?
Reply:I'll through in Walter brand just to confuse you further!Do you have a local welding shop or auto parts store? Probably buy by the box from them.200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
GMT+8, 2025-12-30 17:30 , Processed in 0.095417 second(s), 18 queries .
