CK Superflex cables, did I get the wrong one?
发表于 2021-8-31 22:38:10 | 显示全部楼层 |阅读模式
Igot a CK TL210 25' 1pc tig torch for Christmas that should have the superflex cable on it. The box even has multiple stickers that say superflex but the torch cable is black like a standard cable. Did they put the wrong torch in the box? I am used to seeing the red nylon cables that their other ones have.TOO MANY TOOLS & NO MORE SPACE
Reply:I think the superflex hoses come in a few colors, does it feel like a standard rubber torch hose?Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:It does feel like a larger version of my 17 1pc torch. The retailer only lists the superflex cables but the parts breakdown in the box shows they also use high flex rubber cables too. I saw in an older video that they used to use the black before they switched the different colors like you said.TOO MANY TOOLS & NO MORE SPACE
Reply:The red nylon hoses are part of the 3-piece hose set for water-cooled torches. I have never seen a 1-piece cable that is red nylon.JohnA few weldersA lot of hammersA whole lot of C-clamps
Reply:Originally Posted by Silicon-basedThe red nylon hoses are part of the 3-piece hose set for water-cooled torches. I have never seen a 1-piece cable that is red nylon.John
Reply:Originally Posted by chevydylwell sir just search around on ebay and I only see red superflex nylon 1pc air cooled cables on ck torches.my flex loc has a standard cable that is black.on the box does the part number for the torch have an SF in it?
Reply:I've been searching, but can't find much info on the torch. Where did you buy it? It may be superflex but feels heavy because its bigger than what you have on the 17 torch. Everything I read shows superflex listed with the trimline torches (I assume that's what you got). Can you get a good close up picture of the hose? Does it look woven or just like rubber? Might have to call/email the manufacturer.Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:Well ill tell you my standard cable has resistance in it ive seen vids of the sf cable and it flops around almost like a limp....spaghetti noodlewelding tips and tricks jody has the same torch I do with the valve cept has the red superflex cable....FL1525VSF mine not a sf b7t a flex loc with valve 25ft rubber cable.  You got "hosed* dude hahahaLast edited by chevydyl; 12-25-2013 at 07:58 PM.Miller Syncrowave 210 w/CK FlexLoc 150  3/6/14ESAB PCM 1125 Plasma CutterAtlas 12x36 LatheACER 9x42 3hp millHarig 612 Surface GrinderDRINK Machine              welding&fabrication
Reply:Does it have a braided cover? Go to CK's wed site and look at the superflex video.
Reply:they most certainly come in black and all sorts of colors.  Until we see a picture or you call/email the mfg/'seller, seems like you ain't gonna know what you got. 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:I will call Arc-Zone in the morning. They assembled the machine plug to the torch so maybe it was put in the wrong box. I just wanted to make sure of what should have been on it before I call up.ThanksTOO MANY TOOLS & NO MORE SPACE
Reply:what is the outside diameter of the hose?  Also, as ironrail asked, does it have a braided nylon outer covering?  If it is near ~5/8" OD (regardless if it has a braided covering or not) it is likely standard rubber.  If it is around 5/16-3/8" OD with a braided covering, then it is likely a superflex hose.  This is just going by what I have seen/owned.Last edited by Oscar; 12-25-2013 at 09:57 PM. 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:Originally Posted by Oscarwhat is the outside diameter of the hose?  Also, as ironrail asked, does it have a braided nylon outer covering?  If it is near ~5/8" OD (regardless if it has a braided covering or not) it is likely standard rubber.  If it is around 5/16-3/8" OD with a braided covering, then it is likely a superflex hose.  This is just going by what I have seen/owned.
Reply:You should like it, big difference from my 26 & CS300 torches. Do you have the flex-loc torch? I'm thinking of adding that one next.TOO MANY TOOLS & NO MORE SPACE
Reply:Originally Posted by Chris T.You should like it, big difference from my 26 & CS300 torches. Do you have the flex-loc torch? I'm thinking of adding that one next.
GMT+8, 2025-12-30 17:31 , Processed in 0.098736 second(s), 18 queries .
