Arch & Ring Roller support
发表于 2021-8-31 22:38:07 | 显示全部楼层 |阅读模式
Made a support roller for my Arch 7 ring roller. Needed a spot where i can roll long pieces so i made a base and put in some nut's in concrete. didn't want this to stay outside so in needed to stay mobile. could have made the base wider but it will only be used for movement outside, once back inside i will remove the base and bolt it back to the floor. Could have just picked it up and moved it but it weights 148lbs and would get old fast.
Reply:more pics
Reply:Would have to shovel too much snow to use it around here................but great idea for your area!
Reply:71 ss?
Reply:72   and yes is was 80 for the last three days.......
GMT+8, 2025-12-30 17:21 , Processed in 0.121807 second(s), 18 queries .
