Cummins plat bumper
发表于 2021-8-31 22:38:07 | 显示全部楼层 |阅读模式
This is my personal rig, building my plat bumper. what do you guys think? Attached Images
Reply:Looks good.
Reply:I like that very much.My welding truck is a '97 Ram 3500 drw 4x4 w/ a 360 magnum (gutless wonder) and that's very similar to what I want to do for it one day.Have you had a chance to drive it enough to notice if the lack of cooling inlets in the bumper affect the running temp of the truck?Brian LeonardAppalachian Ironworks L.L.C.434 Long Branch Rd, Marshall, NC 28753828 649 9966828 702 [email protected]
Reply:No noticeable difference, am adding some when my new plasma gets here next week though, more for looks and lights. So it should look better too. I hope.
Reply:Also building a flatbed as we speak i hope to finish next week and have it off to powder coat. I cant wait!
Reply:here is a pic Attached Images
Reply:Nice, whats the thickness of the plate?? Did you score the steel and bend then weld or did you cut each peice seperatly and than weld them ??Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:The deck is 1/8in tread plate, and for the headack rack its 1 1/2 .120 wall tube that i bent in my ProTools 105 bender. the frame is all 11gauge and 10 gauge 2x3.
Reply:I have an '03 Dodge. when can you start mine?
Reply:If you are serious shoot me a PM and i can start next week.
Reply:Originally Posted by Fischer FabThe deck is 1/8in tread plate, and for the headack rack its 1 1/2 .120 wall tube that i bent in my ProTools 105 bender. the frame is all 11gauge and 10 gauge 2x3.
Reply:iI read your post wrong my bad.  For the bumper I cut all the pieces out and welded them. The bumper is 1/8, 3/16, 1/4 all reinforced with a 2'' receiver hitch. and bolted to the original frame mounts.
Reply:O and the stinger is 1 1/2 .120 wall DOM Tube.
Reply:Looks a lot like my Road Armour bumper!   I'll post some pix tomrrow.AEAD 200LE, Lincoln precision tig 185, Millermatic 251, Spectrum 625 extreme, Victor torch , Smithy 1220LTD. and  Do all C-4 band saw ,  Always adding.
Reply:Here is my bumper made by Road Armour in Eugene OR.I was not even thinking about welding my own back when I got this, but would probably be up to the task now.   Yours is looking good! Attached ImagesAEAD 200LE, Lincoln precision tig 185, Millermatic 251, Spectrum 625 extreme, Victor torch , Smithy 1220LTD. and  Do all C-4 band saw ,  Always adding.
Reply:Thanks i am going to add some light holes soon.
Reply:Originally Posted by Fischer FabiI read your post wrong my bad.  For the bumper I cut all the pieces out and welded them. The bumper is 1/8, 3/16, 1/4 all reinforced with a 2'' receiver hitch. and bolted to the original frame mounts.
Reply:Thank you i really appreciate that!
Reply:here is more pics Attached Images
Reply:Looks good!  I think I will paint mine black to contrast against the white. Attached ImagesAEAD 200LE, Lincoln precision tig 185, Millermatic 251, Spectrum 625 extreme, Victor torch , Smithy 1220LTD. and  Do all C-4 band saw ,  Always adding.
Reply:That would be cool and look great! Thanks for all of the comments.
Reply:Drool..... Drool... over the Blue truck...Qualified & experienced at welding scrap metal
Reply:Originally Posted by houseoffireLooks good! I think I will paint mine black to contrast against the white.
Reply:Originally Posted by Fabn4FunI dunno - isn't your OEM back bumper black?  I kinda like 'em same color as the truck. Do you live in a pretty quiet neighborhood?  Some novel I just read talked about going to a funeral in Colma.  Kinda like surrounded by cemeteries???Bruce Willis: "... I see dead people..."
Reply:Here it is with just a quick primer job. Attached Imageshow many hours do you have into the bumper?
Reply:Not sure it was an after hours build and didn't work on it straight through.
Reply:Fisher is there any way to get a few Picts from the back of the bumper?    I am designing one for my 2013, and haven't quite decided on how to brace the 2" receiver.   I am questioning myself on bracing.   Don't want to over build, but in the same breath, I don't want to over build either.    ThanksMiller BobcatHarris cutting outfitMiller spectrum 625 plasmaVariety of shopmade tools
Reply:its a dodge but the bumper makes it look good good job
Reply:I do like your front bumper. I've made a few in the last 40 years.  But I never even thought to fab it up so that it had interesting angles.  mine were nearly always just flat on top Maybe a 1 inch radius on all corners, cutout for the wench Etc. Mac
Reply:Your trucks long lost brother.
Reply:Looks good, it would look even better if you would cut that "stinger" off
GMT+8, 2025-12-30 17:21 , Processed in 0.099890 second(s), 18 queries .
