How To Grind Out Rust Inside 3" Pipe?
发表于 2021-8-31 22:38:05 | 显示全部楼层 |阅读模式
Hey, all,I want to practice pipe welding with tig and I have some 3" pipe but it is very rusty inside and out. What can I use to remove the rust inside the pipe so I can TIG it nice?I have a die grinder with cheapo stones, but it just bounces around and the stones wear down FAST. I have a carbide burr for the die grinder but it chatters and grabs. The angle grinder won't fit inside the 3" pipe. I guess I could sand it by hand but that would take about 6 months.What is the normal way of removing rust back an inch or so from the ends of a beveled piece of pipe before tig welding? What tool do I use?Thanks
Reply:Sandblast it.
Reply:Can you stand the ends up in a pan of acid?
Reply:Perhaps a flap wheel:-Chris
Reply:Originally Posted by KelvinI have a carbide burr for the die grinder but it chatters and grabs.
Reply:Originally Posted by CEPReally? That’s how I do it.
Reply:Thanks, guys, maybe my carbide burr is dull. Let me try another one. I like the flap wheel idea, too.
Reply:If you cant manage to grind it for whatver reason, grind the bevel and stand the pipe up in an inch of muriatic acid so it cleans the ID and OD.Welding/Fab Pics: www.UtahWeld.com
Reply:These work good.http://www.lehighvalleyabrasives.com...51-61463622351Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Sanding drum could be used in a pinch, but will wear down very fast, unless they are higher quality sleeves.http://www.amazon.com/26pc-Sanding-D.../dp/B002BJOY0ACentury buzzbox that I learned on 40+ years ago (was Dad's)Crappy Century 110volt mig 70 amp pigeon pooper.Lincoln Idealarc TIG-300
Reply:Originally Posted by KelvinLet me try another one.
Reply:If short pieces soak it in white vinegar for a couple of days.
Reply:Find some clean pipe. Really.You may get it all out, but if it's nasty like I'm used to seeing you're probably best off finding some clean stuff to practice on.I would say if you had a lathe to bore a skim cut out an inch or so in and take a light cut on the outside to take the crud off.If you had a lathe anyways.Expert Garage Hack....https://www.facebook.com/steven.webber.948
Reply:Carbide burr forsure. 1/4 shank.
Reply:Chattering is ususly from hitting a rough spot or jagged edge. Don't spin it wide open.holding down with the right pressure helps too
Reply:Many thanks for all the good suggestions and information. You guys are great.
Reply:Most common in the field around here is the pink aluminum oxide cylinder on a die grinder.  1/4" shank, 1" depth, 1" diameter.  If your tubes are so bad that this stone can't clean it you'll probably find it's too pitted to tig anyhow.  Metal burrs will work but with all the filings you try to avoid them as much as possible.  Also a lot of the chattering with burrs can be due to a bent shank.  Can be pricey.
Reply:Originally Posted by KelvinMany thanks for all the good suggestions and information. You guys are great.
Reply:Originally Posted by 'StangAll good suggestions. You might also try your local auto parts store. A cylinder hone fits several sizes and works great. A glaze breaker for cylinders also works. Just chuck it up in a hand drill and go to work.
Reply:Originally Posted by DanD78A ball hone might work but a rigid stone hone will grab on the weld seam. Dan D.
Reply:Carbide burr bits in a die grinder
Reply:Originally Posted by AndrewDavenport89If I am rocking and rolling on some gravy 2" pipe I don't worry about cleaning the inside. My root pass will burn majority of the garbage out of there.
Reply:Nope haha I was talking about stick. Forgot this thread was about Tig. BUT HEY that cone grinding rock will work to clean it out for tig.
GMT+8, 2025-12-30 16:11 , Processed in 0.175929 second(s), 18 queries .
