Consumables for Thermal Dynamics CM 52
发表于 2021-8-31 22:38:01 | 显示全部楼层 |阅读模式
I bought a cm 52 and now I am looking all over trying to find the correct electrodes and plasma tips. I was just wondering if any one can help...I have no idea what to even look for......????The only place I could call said the part number I gave them didn't even come up in their computer??? But I was told the consumables are easy to find for this machine.
Reply:Will this help?http://www.thermadyne.com/IM_Uploads...on%20Guide.jpgYou might find more info on their site.https://www.mythermadyne.com/thc/en/...atDisplayStyle.No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Could try here as well.https://weldingsupply.securesites.co...19:UNDEF::::PVMM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:electrode =>    9-8215Start cartridge => 9-8213tip   20 amp =>   9-8205tip   30 amp =>  9-8206tip   40 amp =>  9-8207   for drag cuttingtip   40 amp => 9-8208   for standoff cuttingtip   50/55 amp =>  9-8209  for standoff cuttingtip   60 amp =>   9-8210  for standoff cuttingtip  60 amp  =>  9-8252  for drag cutting  1/4" and thinner material  These numbers should be shown on the label on the spare parts box and in your manual supplied with the system.  Thanks Gene
Reply:Do you have the Radnor MC60 torch?  Some Cutmasters were sold with a Radnor torch, which was designed by TD, and sold thru Airgas.  If this is the case you have to buy Radnor consumables.
Reply:Originally Posted by krmbaseballDo you have the Radnor MC60 torch?  Some Cutmasters were sold with a Radnor torch, which was designed by TD, and sold thru Airgas.  If this is the case you have to buy Radnor consumables.
Reply:I found out the hard way also.  The only good thing about the radnor torch is that you can buy an adapter to fit just about any other brand plasma cutter.  I don't think other torches have that capability.
GMT+8, 2025-12-30 16:23 , Processed in 0.097742 second(s), 18 queries .
