Coulda used a cnc plasma, but...
发表于 2021-8-31 22:38:00 | 显示全部楼层 |阅读模式
...I ain't got one. Had to lop off 3 feet from a full sheet (4' X 8') of 1/4" plate. Coulda used the hand held plasma, but, didn't leave meself the time. Awwwhhh!!  Just get the torch. Had to dowse the smoldering bucket of trash, but nothing else got too badly burnt, as if it mattered...  Anyway, I got a new top for my zero cost- shipping crate/ weld table. I had enough to overlay my wooden table at work as well, which is what the 3' was for. I figured it would be easier to handle at home without that 3 extra feet. I'll probably have to make another cut on top of my '73 cutting table.  Yeah, coulda used that cnc plasma cutter. Attached ImagesCity of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Originally Posted by tanglediverYeah, coulda used that cnc plasma cutter.
Reply:Why would you need a plasma, let alone a cnc one? Just learn to cut with a torch and clamp something down to the plate and drag it along. It would look as good as if a plasma did it.
Reply:You're right, a straight edge should have been used. I crammed this into my schedule at the last minute of the day yesterday. Now I get to pay the piper (in grinding). I should be ashamed for not grabbing a chunk of straight edge. It takes all of 2 minutes. ....or I can just dress up the edge with that straight edge and a pair of clamps! Last edited by tanglediver; 08-10-2010 at 11:18 PM.City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Can't you just cut another sliver off the piece, this time with a straightedge?
Reply:Why CNC?  I think a track torch with a provision to hold your plasma torch would do just fine...
Reply:Originally Posted by IrishBrewerCan't you just cut another sliver off the piece, this time with a straightedge?
GMT+8, 2025-12-30 16:23 , Processed in 0.096974 second(s), 18 queries .
