Sa200 for sale
发表于 2021-8-31 22:37:58 | 显示全部楼层 |阅读模式
$4500.00 o.b.o.SA 200 Motor overhauled. Bored .040 over, new pistons, rings, rod and main bearings all new gaskets and seals. Valves relapped and lash set. Carb rebuilt, new plugs and wires. New belt and hoses. Rebuilt starter. New thermostat. New fuel sediment bowl assy. New copper shunt fields in generator. New generator bearing. New main and exciter brushes. New rheostat in welder and in remote. New insulators on output studs. All new switches and wiring. New battery and cables. New automotive metallic paint with hardener. New control plate. New decals. Runs great, auto idle works, comes with remote. No side panels. No leads. Come test it out. Attached ImagesLast edited by redneckexplorer; 11-14-2009 at 06:28 PM.Reason: FORGOT PRICE
Reply:You went through all that trouble with the engine and then only lapped the valves? Nice looking machine you have there.Gordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
GMT+8, 2025-12-30 16:11 , Processed in 0.183436 second(s), 18 queries .
