Anyone use ESAB Atom Arc 7018 AC?
发表于 2021-8-31 22:37:53 | 显示全部楼层 |阅读模式
I might be able to get a bunch of it cheap and wondered if it behaves like regular Atom Arc 7018, which would be nice.
Reply:I didn't know they made an AC version. I just switched to the Acclaim.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:I didn't either.  How does Acclaim run?
Reply:To me it seems to have a littler dryer puddle than the regular Atom Arc.  I ran this weld today. First picture, the second picture is Atom Arc I ran years ago. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:I used atom arc 7018 years ago. I was doing nuke pp work. If IIRC, I was using AC as that was in the procedure called out. I remember it sucked worse than any 7018 electrode I had ever used. I don't remember whether there was a different electrode for AC vs DC.On a sidenote, I used to use whatever 7018 electrode was available in the oven, provided there was none specifically called for in a spec, and whatever welding machine was nearest to where I was working in the shop to avoid dragging 200 feet of lead to weld 15 feet from another machine.
Reply:I had some Lincoln 1/8 7018AC a while back and I didn't care for it. Atom arc AC, I'm sure will be a bit different but that ac rod is a little different on a dc machine. Yes I know I sound retarded. I'm going to my room now to think about what I said.Arcon Workhorse 300MSPowcon 400SMTPowcon SM400 x 2Powcon SM3001968 SA200 Redface1978 SA250 DieselMiller Super 32P FeederPre 1927 American 14" High Duty LatheK&T Milwaukee 2H Horizontal MillBryan
Reply:I'm sure will be a bit different but that ac rod is a little different on a dc machine. Yes I know I sound retarded. I'm going to my room now to think about what I said.
GMT+8, 2025-12-30 16:12 , Processed in 0.100143 second(s), 18 queries .
