Burning wire
发表于 2021-8-31 22:37:48 | 显示全部楼层 |阅读模式
Got to work at 7 and now it's noon and I'm already on my second 20lb spool of Alu wire  gotta love those days were you can just flip the hood down and burn.Last edited by abec; 02-20-2014 at 03:18 PM.Reason: Typo
Reply:i worked for a very successful fab shop owner and he often said he wished he could go back to the days of burning wire/rods all day and not have to deal with anything else besides changing rods and punching out at quitting time.i.u.o.e. # 15queens, ny and sunny fla
Reply:I'd shoot myself. I'd rather build-fit-grind-machine-finish-unload trucks-glass bead-build some stairs-press some bearings-drill and tap some holes-turn some threads........I used to glue columns together as fast as they could carry them to me and remove them. A literal assembly line.Nod hood, pull trigger,flip flip flip. Walk 8-10 feet to the other end flip flip flip.NEXXXt Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
GMT+8, 2025-12-30 17:23 , Processed in 0.097471 second(s), 18 queries .
