Oxygen and acetylene cylinders..worth saving?
发表于 2021-8-31 22:37:45 | 显示全部楼层 |阅读模式
Happened across 2 old oxygen cylinders and one acetylene cylinder. These are pretty old , they will have to be hydro tested for sure, and maybe that's completely out of the question with the condition they're in..I've had one tested in the past and it turned out good. I thought I'd see if there's anyone that knows a little more about it.. Hopefully these pictures help...Sent from my XT1080 using Tapatalk
Reply:If you are in the Phoenix Az area I will give you $20 each for them....From the desk of Kevin CaronTrying to be the best me I can!www.kevincaron.comAHP Alpha Tig 200x MillerMatic 251Miller Syncrowave 200
Reply:is that actually you Kevin Caron! big fan of your videos! hahahaVictorPraxairAir LiquideMillerLincoln Electric
Reply:Depends entirely on your local welding shop.  What is the condition of the valves?  As long as the valves are in decent shape, they might be salvageable.  I picked up a few in pretty bad shape recently, but the valves all looked OK.  I cleaned them up as best I could, hit them with a soft wire wheel on a 4.5" air grinder, and then repainted all three (oxy/acetylene set and an Argon bottle).  I painted the oxy green, acetylene black, and the Argon Ford safety blue.  Two of the bottles were out of test date, but I crossed my fingers and took them to my gas guy.  He took all three bottles, charged me for one recert fee, and never blinked an eye at swapping them over.  Not bad considering I had around $35-45 in all three bottles (paint included).
Reply:Is that oxygen bottle a rental? Most private bottles don't have a name of the supplier on the neck ring.Didn't Airgas buy up Airco's bottles?I'd take them into your supplier and exchange them for full bottles. Depending on the place they may or may not charge you for the hydro on exchange. I wouldn't paint them. Let the supplier handle that after hydro if they feel the need.
Reply:The valves are all functional,  I'll haul em in and see what they say..I didn't know if there was a certain time period where the bottles are so old they aren't any good ?Sent from my XT1080 using Tapatalk
Reply:Welcome to the forum Keith.Lincoln A/C 225Everlast P/A 200
Reply:I agree with forhire . I took a old cylinder in with a last test date of 1970 and they exchanged it out. It depends on local supplier, they all have their own policies and prices
Reply:Originally Posted by Keith_RehmI didn't know if there was a certain time period where the bottles are so old they aren't any good ?
Reply:The local welding gas place, Norco, asks that tanks not be painted as it might cover up defects.Lincoln Precision TIG 185.Flex-Loc 150 torch.Super-Flex hose.Lincoln MIG 180.Victor Oxy/Act torch set.DeWalt Bandsaw with SWAG stand
Reply:they really don't look that bad from the pics… i took one to air gas recently about like that or worse. he swapped and didn't mention anything about it- Christian M.C3 Welding & Fabrication - CNC Plasma Cutting-Mobile Welding-Custom welding and fabwww.c3welding.com
Reply:Sheesh those things are just babies.  I could swap them without question.  But, if all else fails the wind chime people will buy them.
Reply:They will swap them without testing them first? Huh, the last time I brought one in that was out of date , they had to have it tested first, and if I remember correctly it looked almost mint compared to these ones...Sent from my XT1080 using Tapatalk
Reply:You should have seen the persons face when we were walking around an old farm place and I seen those tanks laying in a heap of junk, I said "hey would you be interested in getting rid of those tanks?" They said " what in the hell would you want those rusty P.OS. things for? If you want them go ahead!" So I unburried them out of a ton of stuff, drug them into my truck...I figured if they weren't any good , no loss.. Its those type of chances I like to take...and if they are good. .... Rock on! Sent from my XT1080 using Tapatalk
GMT+8, 2025-12-30 17:21 , Processed in 0.072215 second(s), 18 queries .
