Miller plasma leaking air
发表于 2021-8-31 22:37:39 | 显示全部楼层 |阅读模式
Hi there,I've got a Miller spectrum 375 plasma cutter. Recently it started leaking air out of the bottom of the water trap. I've taken the trap apart, inspected and reassembled it and it still leaks. I was wondering if this is a normal wear and tear item that needs replacing or if its something more serious.Thanks!
GMT+8, 2025-12-30 17:23 , Processed in 0.072985 second(s), 18 queries .
