pics of my new atlas lathe
发表于 2021-8-31 22:37:39 | 显示全部楼层 |阅读模式
here are a few pics of my lathe and tooling that came with it.Everything seems good and tight and in working order except the 4 jaw chuck.The wood stand even has a metal atlas badge on it
Reply:Nice little lathe.What size (swing)?With back gear?I use my little lathe all the time.Wish it had come with a steady rest like yours.Miller a/c-d/c Thunderbolt XLMillermatic 180 Purox O/ASmith Littletorch O/AHobart Champion Elite
Reply:Nice. I just picked up a 12x36 Atlas I am making a stand for right now. Can;t wait to start learning. I have read the manual about 5 times now, but it doesn't make sense till I put it to use.
Reply:Its a th54 10" swing 36"center to center and yes it has a back gear.I havent made anything with it yet but it sure is fun playing with it while i learn to use it.Next on my list is a small milling machine.
Reply:The middle chuck is NOT for drilling or milling.It's an armature chuck,used like a steady rest but on the tailstock.Set it on the work just tight enough that the work will rotate with no play then l tighten the lock ring and keep the brass jaws oiled when rotating the work in them. It's a handy accessorie.Make lots of cuttings,you are going to have fun.tractor,loader.dozer,backhoe,and all the tools to keep em movin
Reply:Nice find, hondaman!!One accessory you should try to find is a Jacobs headstock chuck, Model 59B.It screws right on to the spindle nose and is great for smaller diameter work (3/16"-3/4").Here's a pic:Funny, I just noticed that the conduit on the wall looks like it's being held by the chuck.There's nothing in the chuck in the pic.Keep an eye out for a quick change gearbox, as well. They turn up on Ebay from time to time.My '47 TH48Rex
Reply:The Quick Change gearboxes on E-Bay go for approximately $399-$599.  Do a search for "Craftsman Lathe" or "Atlas Lathe", all kinds of parts will come up.Welcome to the addiction..............MarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
GMT+8, 2025-12-30 17:21 , Processed in 0.069655 second(s), 18 queries .
