Thermal Dynamics dynapak 110- wont start?
发表于 2021-8-31 22:37:32 | 显示全部楼层 |阅读模式
i have Thermal Dynamics dynapak 110 plasma cutter. when you turn it on the heat overload sensor kicks on and the machine wont cute. is there reset? or do you replace a part?
Reply:Probably a thermal switch, sometimes they are replaceable if not imbedded inside a transformer. Call Thermal Dynamics (Victor) tech service, I'm sure they can help.Jim Colt  Hypertherm Originally Posted by ryanoi have Thermal Dynamics dynapak 110 plasma cutter. when you turn it on the heat overload sensor kicks on and the machine wont cute. is there reset? or do you replace a part?
GMT+8, 2025-12-30 17:29 , Processed in 0.115134 second(s), 18 queries .
