Using fire hose as cheap option for cable sleeve for spool gun leads
发表于 2021-8-31 22:37:29 | 显示全部楼层 |阅读模式
Saw on CL the local fire department is getting rid of a whole bunch of older fire hose, so I made a donation to the firehouse and got a 50' roll of 2" canvas covered fire hose. I cut the outer shell off of the hose and am going to use it as a cable cover (along with some zip ties) for my 30' leads from the Spoolmatic.  Hoping it protects enough to prevent chafing, but it's better than nothing and cheaper than the actual cover they sell for the spoolmatic..  I need to find those low profile zip ties... does anyone know where i can get them locally?  Ace Maybe? Home Depot?Lincoln Weldanpower AC/DCLincoln LN-25Miller WC-115a Miller Spoolmatic 30aCheck out my youtube TV Channel
Reply:I wonder what it would cost to find someone to sew on some velcro?MM252 30AMaxstar 150STrailblazer 301gDialarc 2509100XX Hypertherm PM 30                      Milwaukee4 BaldorsKohlswa shop anvilScott truck anvilStonewell farrier rig
Reply:I was thinking about asking the ole lady to break out the Capitol Sewing Machine... Might cost me a few dinners... but I actually worry about there being enough material left over once you fold over the edge to prevent fraying...  I might ask and see what she thinks..Lincoln Weldanpower AC/DCLincoln LN-25Miller WC-115a Miller Spoolmatic 30aCheck out my youtube TV Channel
Reply:That covering is actually nylon, not canvas. After cutting it you can run a propane torch along the edge to fuse it together to prevent fraying. Kind of like wrapping a nylon rope with electrical tape, cutting through the tape and burning the ends of the rope to prevent fraying. You may have to experiment with the speed you need to move the torch along the edge to fuse it right, but you have enough to do that with on the left over portion.
Reply:Thanks for the tip, I will try that.Lincoln Weldanpower AC/DCLincoln LN-25Miller WC-115a Miller Spoolmatic 30aCheck out my youtube TV Channel
Reply:Originally Posted by PlowboyThanks for the tip, I will try that.
Reply:Great idea Plowboy.A good hot heat gun can do the job too and leave a more "attractive" appearance.I used to use new 2" outer jacket (purchased from the hose manufacturer) to encase dual 1" fire hose for dual agent hose reels and used the heat gun method to dress the ends as I didn't split it lengthwise.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2025-12-30 18:05 , Processed in 0.099007 second(s), 18 queries .
