Another ATV snow plow
发表于 2021-8-31 22:37:29 | 显示全部楼层 |阅读模式
Finally done!I made a homemade atv snow plow... all plans took from the internet (after long reflections to get the right ones) I can put or remove sides. Change angle of the plow left/right.Plow is easy to remove cause i made a new skid plate that is bolted under my atv. When summers comes i just remove it and cover the tip(not sure of that word) :PMade skates on side so i can adjust the height of the plow.If you guys have more questions, ill do my best for helping you  Attached ImagesPrimary language: French
Reply:Nice job....one thing...it appears in the pictures that the plow sticks out abnormally far from the wheeler itself...is that preference? Or does the picture just make it loom like that....taking a look at my pickup the plow is pretty close to the truckMiller Syncrowave 210 w/CK FlexLoc 150  3/6/14ESAB PCM 1125 Plasma CutterAtlas 12x36 LatheACER 9x42 3hp millHarig 612 Surface GrinderDRINK Machine              welding&fabrication
GMT+8, 2025-12-30 18:05 , Processed in 0.112137 second(s), 18 queries .
