Another trailer build
发表于 2021-8-31 22:37:28 | 显示全部楼层 |阅读模式
I know there is probably a million trailer pictures on here, but thought I would add a few more. 2000lb trailer will fit a 4x8 sheet sized object in the bed, was made to fit into limited access ATV trails. Formed 10ga channel, tab and slot construction for easy frame up, torsion axle underneath I know I have some in process pictures I will post. These two are as it just came from the paint shop.TOOLS AND TOYSSMAW Mid States Inc. "MISSING LINK" 10-150 AMP Buzzer circa 1945ishSMAW Magic Wand 40-60 AMP Suitcase Buzzer circa 1939ishGMAW Hobart 210 IronmanOxy-Propane TorchMany other old and cold goodies"Rusty but Trusty"
Reply:That looks like a well designed and well made little trailer. What did you put down for flooring?
Reply:Thanks,,, I have built a few trailers so far I have another 2000lb'r that I use behind the tractor in the woods I should find pictures for.This one has 3/4 marine ply on the floor and 1/2 marine ply on the sides. I should have put more hooks and tie down points than I did,,, there is a lot,, but seems like you could always need use more TOOLS AND TOYSSMAW Mid States Inc. "MISSING LINK" 10-150 AMP Buzzer circa 1945ishSMAW Magic Wand 40-60 AMP Suitcase Buzzer circa 1939ishGMAW Hobart 210 IronmanOxy-Propane TorchMany other old and cold goodies"Rusty but Trusty"
Reply:Good use of the pop up camper frame    I used one just like it to build a canoe trailer.Brian
Reply:ya would be a good use for one, a lot of guys up this direction use them for ice fishing shelters being the trailer already has a license tag, this one was all burnt and bent from 10 ga sheet steel.TOOLS AND TOYSSMAW Mid States Inc. "MISSING LINK" 10-150 AMP Buzzer circa 1945ishSMAW Magic Wand 40-60 AMP Suitcase Buzzer circa 1939ishGMAW Hobart 210 IronmanOxy-Propane TorchMany other old and cold goodies"Rusty but Trusty"
Reply:Sweet little trailer.  Looks like a straight and clean build.
Reply:Thanks, ya it was a quick build, from tack up to finished welded was about 3.5-4 hours with my MIG. I would wrap up some plans and DXF/DWG files if anyone was interested in one for themselves.TOOLS AND TOYSSMAW Mid States Inc. "MISSING LINK" 10-150 AMP Buzzer circa 1945ishSMAW Magic Wand 40-60 AMP Suitcase Buzzer circa 1939ishGMAW Hobart 210 IronmanOxy-Propane TorchMany other old and cold goodies"Rusty but Trusty"
GMT+8, 2025-12-30 19:48 , Processed in 0.116820 second(s), 18 queries .
