Surplus Machinery & Equipment - 200+ items – Mills, Lathes, Presses, Welder, etc (NJ)
发表于 2021-8-31 22:37:15 | 显示全部楼层 |阅读模式
Hi, below is a list of all the machines and equipment I have for sale. I am not a dealer, but am facilitating the combining of multiple business into a building, and therefore have a lot of overlaping machines and not enough floor space. All machines are set up and can be viewed under power.Please email me at [email protected] or call 732-882-2291 if you want to reach me fast and would like detailed specifications and pictures. I have no problem shipping UPS or Freight. Asking prices are listed next to most items, all items are obo.Presses36 TON L&J OBI PRESS - 3" STROKE - AIR CLUTCH - $690060 TON L&J OBI PRESS - 4" STROKE - AIR CLUTCH - $990085 TON DIE MASTER OBW PRESS - 4" STROKE - AIR CLUTCH - $9900MINSTER 32 TON HIGH SPEED OBI PUNCH PRESS - AIR CLUTCH - $12490150 TON V & O PRESS - 6" STROKE - FULLY REBUILT - $14900220 TON KUKIL OBW PRESS - $29900PRESS TYPE WELDERFederal PA-2-12 100 KVA Press Type Welder - $7490100KVA Jefferson Transformer, 240x480 High, 120/240 Low - $990COIL CRADLES8,000 Lb ROWE 8030J Coil Cradle - $59002,000 Lb ROWE 2020J-PR Coil Cradle - $17902,000 Lb ROWE 2020J-PR Coil Cradle - $17904,000 Lb ROWE 4024J Coil Cradle - $34902000 Lb PRE CC-210 Coil Cradle - $19002000 Lb LITTELL C-20 Coil Cradle/Straightener .125" THK - $4900COIL FEEDERSASL 25001000 LBS JACO JVRE-512-DC Reel - $1990150 LB Rapid Air RH34A Reel - $545FEEDERS12" x 12" PRE B15 Feeder - $299030" x 30" COIL-MATIC Feeder / Straightener .125 Thick - $3490PRESS EQUIPMENT RF3030 - $1750PRE - Press Room Equipment - Air Powered Feeder Stand - $2990DRILLSBOWES BR40X1250/1 Radial Drill - 12" Column & 50" Arm - $5490Orbit 12-Speed Bench Mounted Industrail Drill Press - $299BURGMASTER #OB 1/4" 6-Spindle Turret Drill - $1295Walker-Turner 1216-32 - 4' x 6' steel table and vise $499EFI. FB3 Drill Press 1HP 6 Speed Geared Head - Floor Monted- 18x36 Table - $990VERTICLE BAND SAWDO-ALL MODEL# 1612-3 VERTICAL BAND SAW - 16" x 12" - $3900MILLSOKK MH-3VII Milling Machine - $8900Bridgeport 1.5HP Series 1 - 2J Head - DRO - Servo Feed - $2990Bridgeport 2HP Series 1 - 2J Head - DRO - Servo Feed - $3490SHEARPEXTO 152-J Shear - Pneumatic - 52" - 16ga  - $1495HYDRAULIC PRESS60 Ton, KR Wilson Hydraulic 7G 3MD Electric Shop Press - $34908 Ton Denison C Frame Hydraulic Multipress - $2490LATHEHarrison 10-AA Lathe - 11" x 20" - Precision Tool Room  - $2490Mori Seiki MS-1250 Lathe - 15" x 48" - $3990SURFACE GRINDERBrown & Sharpe 1236 Surface Grinder - 12” x 36” Table - $8900Blohm 818 Surface Grinder - 8" x 18" Table - $39508" x 18" Mitsui MSG-250MH SURFACE GRINDER - PMC &Filter - $5950HONEING MACHINESunnen Hone, Model MBB-1680-C with PF-150 Oil Filter! - $4490MANLIFTGrove SM2633BE Electric Scissor Style Lift Man Aerial - $1495AIR COMPRESSORIngersoll-Rand SSR-EP150 - 670CFM, 150HP Air Compressor - $6490TOOL BOXESLISTA 7 Draw Tool Box Storage Cabinet 40" x 33"- Wood Top & Extension! - $990Vidmar Box - $80096 Draw Steel Cabinet full of O-Rings! - $390FREESTANDING BRIDGE CRANEBLUE CRANE 1 Ton - approx 13.5'Tall, 26' long, 20' wide - $8990YELLOW CRANE 2 Ton - approx 15'Tall, 18' wide, over 80' long - $4990INSPECTION EQUIPMENT3 Granite Surface Plates - 18x24 24x36 & 36x48 - $1490Box 7-draw all testing equipmentIndi Square 18X - 149014" Jones & Lamson TC-14 Optical Comparator w/ 4 Lens - $1490Swaure L B&D TOOL CO - $99Angle Set Starrett WebberGauge Blocks Starrett WebberGauge Blocks .05-.4Gauge Pins Set 13 .626-.75DoAll Gage Blocks 81RMahr Gage Block AccessoriesDoAll Gage Blocks 81RGage Blocks Do-ALLGage Blocks 1-90mm Mahr - $299Gage Blocks HDC IncGage Pins 3 sets #14Gage Pin Sets YellowBox of Extra Gage Pins - $35Height Gauge Gelio 26inHeight Gage B&S 585 19" - $145Brown & Sharpe 585 - 12" Height Gauge w/ Felt Lined Box - $150Wheel Dresser LS TOOLHeight Master MitutoyoRAHN Granite ParallelsJerry CenterStarrett Mechanic / Machinist Level 12" x 1.5"  - $150Tensitron TR-250 Wire & Filament Tension Meter Wood Box "Like New" $345Tensitron TR-250 Wire & Filament Tension Meter Wood Box "Used" $225Renishaw PH1SPI 6" Universal Deep Throat Inside Caliper W/ Dial - $599Dial Caliper 12" Long - .001" Accuracy - $50Starrett No. 123 Vernier Caliper - 26.5" Long - $290Starrett No. 122 Vernier Caliper - 24" Long - $65Starrett No. 122 Vernier Caliper - 48" Long with Box - $1500Brown & Sharpe No. 570 Vernier Caliper - 13" Long w/box - $119Caliper ID Mitutoyo .4-1.4" - $120Bore Gage Diatest.165-.394Bore GageMitutoyo 511-163 Bore Gage - 0.7-1.4" - ACC .0001 - $175Mitutoyo 511-105 Bore Gage - 1.4-2.5" - ACC .0001" - $175Mitutoyo 511-106 Bore Gage - 2-4" ACC .0001" - $165Bore Gage 2-4" Mitutoyo Mitutoyo 511-187 Dial Bore Gage - 4-6.5" - ACC .0001" - $325Mitutoyo 511-214 Dial Bore Gage - .24-.4" - ACC .0001" - $290Bore Gage Federal  1243P-3 - $150Federal 1250P-1 Bore Gage - .5-1" ACC .0001" - $125Federal 1204P-1R2 Bore Gage - .310-.628" ACC .0001" - $159Pea**** 5470 Dial Bore Gage - .75-1.45" - ACC .0001" - $119Starrett No. 220 Anvil Micrometer - 0-1" w/ Box - $99Micrometer Starrett 9-12"Micrometer Starrett 7-8"Mitutoyo 1-2" Blade Micrometer # 122-126 w/ Wood Box - $150Starrett 6-12" Micrometer # 224 w/ Original Wood Box - $290Micrometer NSK 7-8"Mitutoyo 7-8" Micrometer w/ Wood Box - $125Mitutoyo 9-10" Micrometer w/ Wood Box - $155Micrometer 12-13 MitutoyoMicrometer 1in StarrettMitutoyo 146-104 Flange Micrometer 0-1" w/ Wood Box - $99Starrett 0-1" Blade Micrometer # 468 w/ Box - $99Mitutoyo 147-351 Micrometer 0-1" w/Box - Looks New! - $99Micrometer 1-2" Screw Thread MitutoyoMicrometer Etalon 2-3" indicating mic .00005 - $200Micrometer Etalon 3-4" indicating mic .00005 - $250Micrometer Etalon 2-3" indicating mic .0001 - $150Micrometer Etalon 0-2" indicating mic .0001 - $200Micrometer Etalon 0-1" microrapid mic - $75Micrometer Mahr 4-6" .00005Micrometer Starrett Case +Micrometer Gage Starrett 12"Micrometer Gage Starrett 11"Micrometer Gage Starrett 9"Micrometer Gage Starrett 7"Starrett No. 823 Tubular Inside Micrometer 4 - 24" - $199Starrett 700 Inside Caliper Micrometer - 1-2" w/Box  - $119Micrometer Inside Starrett - NO MICMicrometer Inside Starrett 4-12" PouchLufkin Radius Gage SetShore Durometer w/ Calibration Block - ASTM D2240 - $129Pocket Surf III - Mahr Federal - EMD-1500-311 - New - $1750Pocket Surf III - Mahr Federal - EMD-1500-311 - Used - $990Lyman Radius Templates - $40Gauge Starrett - AloneDeltronic Pins + Angel GageElecometerGreenfield Tap - 2 11 1/2 NPT  - $49NPT 2" Tap 11 1/2Brown & Sharpe Toolmakers' Surface Plate Square 559 - $45MTM Blockstaper micrometerAngle Mic / Taper MicAngle Mic / Taper MicTaper-Mike 311DoAll Gage Set #9Model M-O Plug Gages - $50Brown & Sharpe 1.4000 Ring Gage - $99Chamfer Gage Barcor Model# 1127 - 90-127 deg - 0-1" - $125DoAll Black Granite Dressing PlateSteel Stamping Letters - $40SPI-SPE Mold Comparison Kit - $149MicrostatAlina Copr 12" G1730TOOLSKURT II VISE Model # PT-800A - $990KURT ANGLOCK VISE Model # D675 -$325(2) SOILD STEEL TABLES - 6'Lx30"Wx35"T - 2" THICK TABLE - $1990Kalamazoo 3HP, 10" Abrasive Cut-off Wheel with stand - $399#15 Royersford Excelsior Kick Press - 3 3/4 Ton - $490Greennerd NO2 Arbor Press 2 Ton - $199Redingtion Counter - $50Lucifer Furnace 7021-C - 6"x6"x12" - 2000 DEG F - $850FLEX ARM S35 400rpm Tapping Arm - Very Nice Setup Table - $1990TECO FM100 FLUXMASTER 30HP 3PH 460 VOLT MICRODRIVE - $490PYH DemagnetizerPELOUZE 60 LB SCALE - $99Baldor 1/2 HP Industrial Pedestal Grinder 3800RPM - $450Delta Triple Duty Pedestal Grinder- 1/2 HP 3450rpm - $390(2) 5 step ladder on wheelsSetco M3BL & P3 slides3 sided in-plant modular office - 9' x 14' - A/C - $990Square D Class 9007 Series A Limit Switch - $99Porter Cable Wet-dry belt sanderFan TPIFan NOVA AirmasterPAX 5-6 OilerBlack & Decker(2) Wilray Fire Cabinet PDCS-55Yellow Steel SawhorsesRolling Cart Yellow SteelRolling Cart Blue - Push HandleDayton Welding CartDayton Professional Wet / Dry VacuumOtherVery nice receptionist's desk - Solid Wood - Over $8000 new - $19001.3 Million Button Parts! - Standard Various Sizes - $9900Toshiba DP3580 Office Coppier - Over $8,000 New!! (was working but wotn power on) - $400(2500) 1-1/2" Nylon Sliding Door Rollers for Marshall - $175020,519 LBS - Tin Plate Foil Inventory - 0.0082 & 0.0105 - $7900ALL items are being sold in as is where is condition, with no representations, warranties and/or statements of fitness and/or merchantability implied whatsoever. The items are not warranted for any particular purpose or use. All liability rests solely with the purchaser and/or his successors and/or assigns.
GMT+8, 2025-12-30 19:45 , Processed in 0.292363 second(s), 19 queries .
