Magnesium filler?
发表于 2021-8-31 22:37:12 | 显示全部楼层 |阅读模式
Is there anything cheaper than ERA392A for welding magnesium? A guy asked me if I could fix  up two small drilled holes and one of the head bolt holes in his VW engine case so I told him I'd look into it. Looked in Enco and found that rod at $237. for one pound of 3/32" 14" long, and 1/16" was even more.It's only a favor I'd be doing but I think I'll have to turn him down if it's gonna' cost so much. There's commercial VW places to help him but it's got me curious if that particular filler is the only way to go. could it be patched with the almost universal ferrous metal 3000 fill rod?I THINK I can just melt the little holes closed but the head bolt hole is screwed up to just under 1/2" diameter.MM210TA186TA95sLincoln AC/DC Tombstonegood old Smith torch setup 24v Readywelder mig w/spoolgunSB H 10 latheBridgeport mill6x12 K.O.Lee surface grinderK.O.Lee tool/cutter grinder
Reply:VW cases are the hard to weld, Find an old one to practice on.
Reply:The old cases are generally repaired with "Case-Saver" inserts. The new performance cases have Case-Savers already installed.Last edited by shovelon; 01-06-2014 at 03:14 PM.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Originally Posted by shovelonThe old cases are generally repaired with "Case-Saver" inserts. The new performance cases have Case-Savers already installed.
Reply:Measure the hole. It just may need a threading and the case saver install. I don't know if 2 case savers are installed on that foto, but it would not be beyond me to try it.Last edited by shovelon; 01-08-2014 at 03:57 PM.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:And no. You cannot solder those holes.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:KingsertTim Beeker.
Reply:Originally Posted by shovelonAnd no. You cannot solder those holes.
Reply:Originally Posted by tnjindKingsert
Reply:Originally Posted by hillNot maybe with some stuff I have called "Aluminum soft solder" and isn't solder in the normal meaning of the word.
Reply:OK, Thanks for that. Originally Posted by hddnisMy experience is that stuff will just make a huge mess out of what you are trying to repair. I had a friend bring me a chainsaw case that he had tried that on and it was a mess, I had to cut out a huge chunk and make a patch for it to get past the contamination.Mr. HE
GMT+8, 2025-12-30 19:46 , Processed in 0.310538 second(s), 19 queries .
