Miller 200 millermatic tig attachment
发表于 2021-8-31 22:37:09 | 显示全部楼层 |阅读模式
Hi all, Do they make a tig set up that works on the millermatic 200 mig? I have a spool attachment for it for alum. and have used it for stainless. It is a dc machine. I was just wondering about it? Thanks, David
Reply:Mig is a constant voltage process. Tig is a constant current process, so no, there isn't an attachment that will allow you to do tig off your MM200 mig welder..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Hi, all  I did see cv on the welder. I should be more up on welding and welders then i am sence i do some much welding. That's why i tell people that want something welded to have someone that knows what they are doing.Thanks, David
Reply:Felgar if you have a stick welder, you could tig weld with it.
GMT+8, 2025-12-30 19:47 , Processed in 0.096580 second(s), 18 queries .
