Anyone Else Do This???
发表于 2021-8-31 22:37:09 | 显示全部楼层 |阅读模式
I cut my filler rod down to 18" for several reasons. In a small garage 18" is easier to handle that 36" also I keep my filler rod in a tool box. I got tired of getting too close to the arc and throwing away small bits of filler rod that still had some use. I came by this mechanical pencil and use it to hold filler rod. Another choice would be a tungsten holder. I can get down to about an inch on the filler rod using this. Currently using this with 3/32 filler wire.
Reply:Pretty slick idea, I typically just go until my fingers burn lol. Then throw the small piece in the scrap metal bin
Reply:ESAB thought it was a good ideahttp://products.esab.com/Templates/T041.asp?id=59386NickESAB CaddyTig 2200iPowermax 45MM140 (Sold)
Reply:I cut the tig rods down to to help someone in the shop from accidentally getting poked with a 36" rod if they happen to walk up while im welding. I just feed the rod in my hand till theres only about 1.5" left and toss it in the scrap bend
Reply:That's cheating man! Boooooo! No excuses for poking eyes or anything!I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:I just feed wire with my fingers, when my gloves start smoking and fingertips burn I throw the rest away. At $2.55LB for ER70S2 I don't mind tossing a little away if it saves time. If the piece is long enough I will save it for tack welding, since its a short weld my fingers don't get as hot.Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:^ ^ ^ this ^ ^ ^.  Used to cut full lengths in half.  Not any more.  Use the full-length fillers with a quick 90deg bend in one end.  Allows concentrating on properly feeding the filler a la finger manipulation.  Basic.   When the bends arrives, time for the round file.  Done."Discovery is to see what everybody else has seen, and to think what nobody else has thought" - Albert Szent-Gyorgyi
GMT+8, 2025-12-30 19:48 , Processed in 0.096847 second(s), 18 queries .
