Belt gaurd I built for some Frankenstein roof plainer. The second set of pics is the blades I make and replace using saw blades. Things scary looking for sure. Attached Images
Reply:Some pics of the blades. I'll post more later Attached Images
Reply:What kind of work do you do with such a beast?Is it for removing roofing? Shingles? Shakes? Torchdown? Mr. HE
Reply:this is what google says it is forThe Garlock Rotary Planer is built for demanding roof surface cleaning and preparation projects, such as clearing off blisters, repairing gravel stops, preparing tie-ins or performing large-scale patch work. This machine creates a 12-in. path of smooth, planed surface for small-and large-scale BUR repairs.Lincoln 225 ac (my first machine)farmhand 115vac 70amp mig/fc toymiller aead 200le (my main machine)
Reply:Feuded is on it, the ones we use are called roof scarifier. We use it on foam roofs. Here's a pic of a couple we converted from lawn combers. The other pic is the custom shaft we had made at the machine shop(215ea). Attached Images
Reply:Modded my little brothers exhuast on his moped. It had a little piece of 3/8 tubing coming out of the muffler, with about a 6" piece inside of it. I cut it off and unibited the hole to one inch for the new tip. Sounded a lot better, he gained 8mph up my street. It also has a big bore kit on it. I wanna make a custom muffler for him. Attached Images
Reply:Here's a Handel I made for a roller. It gets filled with water so it can get heavy at times. The handles that come on these are ****, as much as they get used they just fall apart. The favorite toy in the shop. I used the tig to weld the center lug for the bolt I tapped from some round stock to a 7/16 thread. Attached Images
Reply:That is some interesting stuff! Looks like it could mow the lawn after working all day as well.
Reply:Originally Posted by VPTThat is some interesting stuff! Looks like it could mow the lawn after working all day as well. |
