Spring Rate Tester
发表于 2021-8-31 22:37:06 | 显示全部楼层 |阅读模式
Here's a spring rate tester I put together.  Has a Wixey height readout made for a router table and a load cell I got off of eBay.  Powdercoated it with some sparkly blue I had for another project. Thermal Arc Fabricator 281Miller 350PMiller Syncrowave 200Lincoln ProCut-55Jackson NexGen
Reply:Thermal Arc Fabricator 281Miller 350PMiller Syncrowave 200Lincoln ProCut-55Jackson NexGen
Reply:That is a beautiful thing! Am I to assume it's for testing automotive springs? And if so...why? Could you further enlighten some of us unenlightened? Nice looking rig, though...POVERTY...is the Mother of InventionMillermatic 211Millermatic 140Miller Thunderbolt XLArcOne 100STS inverter w/TIGThermal Dynamics 38XL Victor Oxy/AcetyleneJancy Slugger Holemaker IIJet 5x6 BandsawNever enough time & sleep.
Reply:Yup, it's for automotive springs.  I work in a race shop and a lot of the time the spring rate marking gets worn off the spring and this little machine will give the spring rate, usually in lbs/in or kgs/cm.  There's quite a few available for purchase, but I couldn't bring myself to spend $900 for one.Thermal Arc Fabricator 281Miller 350PMiller Syncrowave 200Lincoln ProCut-55Jackson NexGen
Reply:Looks nice, is there something to hold the spring in place so there's no chance of having one eject?Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:B.S! js;you made that? looks like store bought.  great build. btw, why would you need to know how strong that spring is? sorry just read the above post that answered my question. again, nice work.Last edited by docwelder; 03-02-2014 at 06:38 PM.i.u.o.e. # 15queens, ny and sunny fla
Reply:Originally Posted by SquirmyPugLooks nice, is there something to hold the spring in place so there's no chance of having one eject?
Reply:Originally Posted by docwelderB.S! js;you made that? looks like store bought.  great build. btw, why would you need to know how strong that spring is? sorry just read the above post that answered my question. again, nice work.
Reply:what is the length range on springs you are able to test and how would you measure progressive springs?  Looks great.Multimatic 200Ellis 1800Haberle S225 9" cold sawMM 300;  Spoolmate 30A w/ WC-24TB 302GDynasty 280 DX Tigrunner
Reply:Originally Posted by Drooopywhat is the length range on springs you are able to test and how would you measure progressive springs?  Looks great.
Reply:Good job. Has a very "Professionally built" kind of look to it.so all the measurements are electronic/digital readout?Would it be worthwhile to use a micro controller like an Arduino to integrate the readings to just readout the rate?Don't talk about it, Just do it!
GMT+8, 2025-12-30 18:05 , Processed in 0.100453 second(s), 18 queries .
