AC Motor Mount
发表于 2021-8-31 22:37:06 | 显示全部楼层 |阅读模式
Removed mount from old drill press.Had 1/2 hp ac motor. Changed out to 1 1/2 hp 180 volt DC.Top holes on mount where exact, bottom holes where near edge.Added 2 tabs with 1/8 joggle.Welded 7018 rod, usually use 6013. 7018 is hard to start compared to 6013.Charl
Reply:Good job!! As for the 7018 hard to strike. When you break the arc and the rod tip cools for a few seconds, with your gloved hand break the concaved flux off the end of the rod. That's what happens when you pound the end of the rod trying to start the arc.                                                 MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Wheres the weld? Must be covered under that flux....cmon man we wanna see a solidified puddle of metal not flux lolso where does the 180v Dc come from?Miller Syncrowave 210 w/CK FlexLoc 150  3/6/14ESAB PCM 1125 Plasma CutterAtlas 12x36 LatheACER 9x42 3hp millHarig 612 Surface GrinderDRINK Machine              welding&fabrication
Reply:Nice job.But just to be rude, wouldn't MIG have been better for thin stuff like that?Be wary of The Numbers: Figures don't lie,. but liars can figure.Welders:2008 Lincoln 140 GMAW&FCAW2012 HF 165 'toy' GTAW&SMAW1970's Cobbled together O/A
Reply:Originally Posted by chevydylso where does the 180v Dc come from?
Reply:I don't want to break your bubble but as far as HP involved, from .5 hp ac tp 1.5 hp dc  the max torque of your new dc motor could very well be 10 to 15x what you had before...   You can surely validate with more accuracy how stronger is a dc over an ac motor, not being at shop my manuals are out of reach for now, good luck.
Reply:from .5 hp ac tp 1.5 hp dc the max torque of your new dc motor....Right on!!!  Its got a lot of torque. Charl
Reply:I'd like to see the motor mounted up. I have been thinking of doing this with my DP too.
Reply:Where did you get such a motor?European 220v treadmill or something?Welding/Fab Pics: www.UtahWeld.com
GMT+8, 2025-12-30 19:55 , Processed in 0.098780 second(s), 18 queries .
