Clausing and Atlas lathes, compatable?
发表于 2021-8-31 22:37:01 | 显示全部楼层 |阅读模式
I heard that Atlas made the Craftmans lathe for Sears, and they also bought out Clausing back in the early 1950's.... Question is, I have a Clausing 5935 12" lathe, probably made in the 60's,  I need a tailstock, it had none when i bought it, there is a nice tailstock on ebay for a 12" sears lathe, what are the chances that it will fit? or can i MAKE it fit.......
Reply:Originally Posted by 1awert1I heard that Atlas made the Craftmans lathe for Sears, and they also bought out Clausing back in the early 1950's.... Question is, I have a Clausing 5935 12" lathe, probably made in the 60's,  I need a tailstock, it had none when i bought it, there is a nice tailstock on ebay for a 12" sears lathe, what are the chances that it will fit? or can i MAKE it fit.......
Reply:The Atlas machines have flat ways and if I understand correctly the Clausing has 'V' ways.
Reply:O.K.   Thanks, I will keep looking but some people are a little Greedy, I mean 400 to 600 bucks for a tailstock is crazy, i paid $650 for the lathe, less tailstock.......
Reply:You should be able to score for less than $400 from a used dealer.I just looked at Plaza's site. Joe Bergamo, owner, has several parts for 5900 series T/S listed but not a complete unit. This is not to say you're out of luck. You should e-mail him as his listings are not always up to date. I'll try to find some other links.Last edited by dunemetal; 09-27-2010 at 11:14 PM.
Reply:Try also www.mebfab.com. Dan has a complete unit listed for $200.Good Luck
Reply:Hay, thanks........
GMT+8, 2025-12-30 19:45 , Processed in 0.091379 second(s), 18 queries .
