What is this ??
发表于 2021-8-31 22:37:01 | 显示全部楼层 |阅读模式
Hi !Someone may let me know the full name of this device ??ThanksJohn
Reply:DNMB turning insert?"No man's knowledge here can go beyond his experience." - John Lockewww.improvised-engineering.comManufacturer Agnostic:Blood----------Sweat---------Tears----|------------------|----------------|----Lincoln Red, Miller Blue, Esab Yellow
Reply:paper weight!!!!200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
Reply:Sorry, upon closer look at the through hole, the one sided chip breaker and the relief angle, I'd say it's a DEMM turning insert --Wintermute"No man's knowledge here can go beyond his experience." - John Lockewww.improvised-engineering.comManufacturer Agnostic:Blood----------Sweat---------Tears----|------------------|----------------|----Lincoln Red, Miller Blue, Esab Yellow
Reply:Hi!Is it reqwired the full name of the device ??  Newton
Reply:Wintermut:What means DNMB ?Im curious to know the name of that thing!ThanksTony
Reply:Originally Posted by tony mattWintermut:What means DNMB ?Im curious to know the name of that thing!ThanksTony
Reply:I've just been given a Sandvik Boring bar, with the Code S25T-MWLNR 06using the link provided by wintermute, I can't find out what insert it takes, can you help me.
Reply:All is fine, just found this  on the same site. Cheers Wintermute
Reply:Yes, I gess the material is tungsten carbite..Is correct ?
Reply:couldn't tell you if it's a carbide insert, HSS with a coating or something else entirely...about all I can tell you are my guesses as to it's ISO designation.  I obviously couldn't even tell you the size specifications without having it in hand to go over with a micrometer.--Wintermute"No man's knowledge here can go beyond his experience." - John Lockewww.improvised-engineering.comManufacturer Agnostic:Blood----------Sweat---------Tears----|------------------|----------------|----Lincoln Red, Miller Blue, Esab Yellow
GMT+8, 2025-12-30 18:05 , Processed in 0.112058 second(s), 18 queries .
