For Sale: Miller Regency 200 Power Source + WC-24 + 30A, 230/460V Single-Phase, $1111
发表于 2021-8-31 22:36:57 | 显示全部楼层 |阅读模式
Pay with PayPal if you don't have the cash!Miller Regency 200 CV DC Source + WC-24 + 30A Spoolgun! Runs off 220V or 460V, Single-Phase. This is a Constant Voltage power source for powering a spool gun, wire feeder suitcase or push-pull setup. It works fine and includes the attached Miller WC-24 spoolgun adapter as shown AND a Miller Spoolmatic 30A spool gun (not shown). Also includes flowgauge, work lead (underneath), aluminum cart and chain to attach tank. The 30A will need a wire speed control rheostat installed (included, used--you install). The outer rubber insulation of the 30A control wires is deteriorated in areas but the insulation of the wires is intact. Deduct $311 if you don't want the 30A.This has 6 power taps and hi and low for each. I've charted voltages for each setting and at "low/4" it easily welds 1/4" aluminum so there is plenty of voltage for thicker metals. My "3rd gen" 30A wire speed was at "4" on a scale from 0-9. 60% duty cycle at 200 amps. This has the standard 14-pin connector on the front.This is surplus to our needs and must go. Come test in our shop--you can use my 30A or bring your own suitcase or wire feeder--Miller recommends the 22A. Note that I've modified one of the power port proprietary connectors so you can easily attach a lug. I've also added a rubber pad to the top for placing tools, etc. The included 30A will need parts and repair before you can use it. This is a good supplement to your engine driven setup--use your CV attachments without the noise or fumes. BTW, this has fan-on-demand so the huge cooling fan is quiet while sitting there. Power supply Ser. # is KB145202, stock # 903077 and WC-24 Ser. # is KG029822, stock #137549. I don't have the serial # of the spoolgun but it is a 30A "1st gen" model.Price includes packaging and palletizing but note that the cart may have to be cut to fit on the pallet. You will simply weld it back together once you get it to your shop. This will be shipped from a commercial location but you will need a truck with a liftgate as access to a forklift can not be guaranteed. I'm guessing it is about 200lbs with accessories shipped from 32771 if you want to check shipping costs. I'd be happy to knock off a bunch of money for local pickup of this package. Please PM if you have any questions and/or are interested. Thanks for looking! Attached ImagesMM252 w/30AMM140 w/o AS w/SM100 w/CO2TA ArcMaster 185 TIG/StickTA 85 TIG/Stick LunchboxHobart (Miller) AirForce 625Hobart AirForce 250ciVictor O/A (bored)Lincoln Patriot AutoShade (freebie)45ACP for those stubborn jobs...
Reply:UPDATE: Regency 200 sold locally--thanks for looking!MM252 w/30AMM140 w/o AS w/SM100 w/CO2TA ArcMaster 185 TIG/StickTA 85 TIG/Stick LunchboxHobart (Miller) AirForce 625Hobart AirForce 250ciVictor O/A (bored)Lincoln Patriot AutoShade (freebie)45ACP for those stubborn jobs...
GMT+8, 2025-12-30 19:30 , Processed in 0.501840 second(s), 27 queries .
