Everlast 160STH Foot Pedal Options
发表于 2021-8-31 22:36:53 | 显示全部楼层 |阅读模式
Hello everyone, this is my first post, I'm glad I finally joined, lots of useful information on here.  I recently just purchased a Everlast 160sth TIG/Arc welder earlier this week, and should be having in my home shop Tuesday, my question is, it has high frequency start, and comes with a switch activated torch, I would like to use a foot pedal with this machine, but brand new from Everlast is a bit much for me right now, is it possible to use any 7-pin connector foot pedal with this machine?  Or do I have to use the one that is offered from Everlast?  Say, can I use a Miller Maxstarr pedal, or will the internal wiring be different, or will it not matter, and should work?  Cause I understand that all the foot pedal is, is a remote rheostat, and that the only problem that I can foresee running in to is the internal wiring of the foot pedal.  Any insight or recommendations will be helpful.  Thank you.
Reply:Everyone uses different potentiometer values and some use different amounts of wiring. Some use 5, some use 7 wires etc. Some also use more than 1 switch.See if SSC makes one for that machine.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:when I got mine I was told that the american made one from everlast would not fit the 160 sth. the other one seems to work fine so faryou ain't gotta eat it
Reply:It almost seems that it would have been better to have bought the itig200 since it come with the pedal, but I have heard nothing but good things about this welder, ksmrf how are you like your so far?  M J Mauer thanks!
GMT+8, 2025-12-30 19:29 , Processed in 0.100784 second(s), 18 queries .
