Backpurge Tank Holder
发表于 2021-8-31 22:36:50 | 显示全部楼层 |阅读模式
I made up a little stand for an extra argon tank for backpurging.  I was tired of rolling around an extra tank and was always worried about knocking it over.  Right now I just have a single quick disconnect fitting, but I'm planning on making a small manifold to have 3 quick disconnects along the front edge and using some magnetic bases with quick disconnects with some more flexible tubing attached.  Right now sometimes the coiled cable can pull the workpiece around if you're not carefull.Last edited by jschulze; 03-02-2014 at 10:18 PM.Thermal Arc Fabricator 281Miller 350PMiller Syncrowave 200Lincoln ProCut-55Jackson NexGen
Reply:Thermal Arc Fabricator 281Miller 350PMiller Syncrowave 200Lincoln ProCut-55Jackson NexGen
Reply:Sweet. Really cool design. You could build a manifold into the front of that right above the storage box for an even bigger "cool" factor
Reply:Thats a cool setup, I purge from the same tank. I run dual regulators on one cylinder, one to my welder the other to my work piece. in 13 years, always worked perfect.'14 HTP invertig 221Thermal Arc 201ts'15 HTP 2400'13 Hypertherm Powermax 30Esab 875Esab 251Clark Metal Servicespecializing in stainless steel exhaust systems
Reply:Awesome work! Like that cool design, great set-up and awesome finish.
Reply:That is an awesome idea!!!!
GMT+8, 2025-12-30 19:29 , Processed in 0.097418 second(s), 18 queries .
