Lincoln tig torch hookup
发表于 2021-8-31 22:36:47 | 显示全部楼层 |阅读模式
The PT185 comes with an air cooled torch rated at 150 amps. I have a 200 amp torch that I would rather use. Is there an adapter that will allow this or do I have to use Lincoln's line of torches?  My torch is a SR-26F-12R with the standard threaded fitting on the hose.
Reply:Josh,Call me at 1-800-872-9353 - we can hitch you up with one.JeffJeff NolandDrive a LincolnDrink a MillerWeld with an HTP
GMT+8, 2025-12-30 19:30 , Processed in 0.102380 second(s), 18 queries .
