Aluminum welding liner problem
发表于 2021-8-31 22:36:45 | 显示全部楼层 |阅读模式
I bought one of those Lincoln kits K662-4 I think for welding Aluminum in my mig welder.  The problem is when I finally got around to trying it I found there is already a wire stuck in the liner, and I can't get the wire to feed in off the spool and push it out. Anyone know any way to get a stuck wire out of a liner?
Reply:Wow thats hard to explaine, first remove the liner from the gun. See if there is any point as to where you could grab it with pliers and jank the thing out. If its really jambed in coil up the liner and flex it a bunch of times, that will sometimes loosen it up and allow you to remove it. Good luckbernie
GMT+8, 2025-12-30 19:22 , Processed in 0.116373 second(s), 18 queries .
