Bending sheet metal to 90 with a 20 ton press
发表于 2021-8-31 22:36:40 | 显示全部楼层 |阅读模式
Hello,http://www.harborfreight.com/merchan...ess-32879.html I saw this online, 170 if I can find it in one of the stores around me.  I feel a bit shamed about the idea of buying it, but I don't have a fortune to spend at the moment.  I may not end up buying this idea any time soon and I'd just wait until I could afford something else.Anyway, could something like this be formatted to bend 90 degree angles in something like aluminum?Miller 330 a/bp water cooledI believe in gun control, I hold my gun with two hands.  If you want to know why, click here.Buy American or bye America.
Reply:Northern sells a brake that will go in a 20 ton press. It's rated at 3/16" x10", 1/4" x 6", 1/2" x 2" in steel, and .100 alum 20" wide.http://www.northerntool.com/shop/too...ct_21896_21896 The one for a 40 ton press bends 1/8" steel 26" wide, 3/16" x22", 1/4" x 10", 1/2" x 4" in steel, and .100 alum 26" wide. This just gives you an idea what sort of tonnage you might need. There have been several home made pres brakes posted here. Steve (7A749) did a nice one a while back as an example IIRC. The big issue with a press brake is getting the die right. Many I've seen made use a piece of bucket cutting edge, or a factory made die blade rather than try and build one..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by DSWNorthern sells a brake that will go in a 20 ton press. It's rated at 3/16" x10", 1/4" x 6", 1/2" x 2" in steel, and .100 alum 20" wide.  http://www.northerntool.com/shop/too...ct_21896_21896
Reply:Originally Posted by pinjasAnyway, could something like this be formatted to bend 90 degree angles in something like aluminum?
Reply:How about supporting a American company.  This looks to be a decent product.http://www.swagoffroad.com/20_Ton_Press_Brake.html
Reply:Originally Posted by Showdog75How about supporting a American company.  This looks to be a decent product.http://www.swagoffroad.com/20_Ton_Press_Brake.html
GMT+8, 2025-12-30 20:05 , Processed in 0.095397 second(s), 18 queries .
