Purox torch tip question
发表于 2021-8-31 22:36:38 | 显示全部楼层 |阅读模式
Have a 3# tip and doesnt want to cut 1/4 in steel what tip should I get brand. Number and where.
Reply:A #3 should cut 1/4" with oxygen and acetylene.  Try cleaning it out with a tip cleaner.  If you want bigger tip,  #4 is the next size up.Purox apparently is handled by ESAB now, so you should be able to get tips through them.  Try www.gossonline.com.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Purox for some reason does not number there tips the same as everyone else. The #3 max capicity according the the link below is 1/4".  So check the tip to make sure it is clean and your pressures are set right. If that does not work, you may have to go to a #4.http://products.esabna.com/EN/home/g...es_4202_seriesOAdoctorwww.regulatortorchrepair.com
GMT+8, 2025-12-30 20:06 , Processed in 0.088060 second(s), 18 queries .
