查看: 13|回复: 0
FS: Wet Sandblaster
发表于 2021-8-31 22:36:35 | 显示全部楼层 |阅读模式
Hey guys. I goy this to sandblast my BBQ trailer and I'm done with is. I used it for one weekend, about 5-6hrs. It hooks up to a 3000psi pressure washer and you pop the hose in a bucket of sand and blast away. No air compressor needed, and no dust cloud. It works just as good as an air sadblaster, but a whole lot cheaperif you already have a pressure washer. I have used it once, it looks brand new, you wouldnt know I used it unless I told you. Comes in the original box, I paid $250 for it, I will let it go for $150I will get some pictures of it tonight.If you cannot convince them, confuse them.         Harry S Truman
Reply:yeah picture would be nice especially one in actionCo-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:pics?IBEW 1412Hobart HH210Lincoln 225ACLincoln Ranger 305DLincoln Precision Tig 185Lincoln Pro Mig 255CMiller Spectrum 2050
Reply:would be interested in seeing some pics as well..also the kind of finish you can expect?
Reply:The first picture is what is included. Its the sand pick-up tube, the hose thats 15' long and then the nozzle tip. It has a ceramic venturie in it to mix the sand and the water. The second and third pic show it hooked up to your own pressure washer lance.I dont have any pics of stuff I blasted without paint already on them, but you get nearly identical results to a standard air sand blaster minus the dust cloud. And it doesnt require a $1500 air compressor if you already have a 3000-5500psi pressure washer.If you cannot convince them, confuse them.         Harry S Truman
Reply:Is there a BRAND ?   Where was it purchased so I can check if parts are available..ThanksEDV
Reply:The box doesnt have much of brand listed. I got it from AmeriTech 14730 N. Nebraska Ave Tampa  FL  33613 Phone # (813) 978-0809, Yes parts are available. The replacement nozzle is like $45 if and when you ever need to replace it, I asked when I purchased it.If you cannot convince them, confuse them.         Harry S Truman
GMT+8, 2025-12-30 21:57 , Processed in 0.071883 second(s), 18 queries .
