Flange welding on tube
发表于 2021-8-31 22:36:33 | 显示全部楼层 |阅读模式
Hi Guys,Am new here and am a student working on a project welded flange on tubes. When welding, the heat reduces the hardness of the tube and destroying the tube properties. A solution of water coolant is needed to cool the temperature from inside when welding. Do anyone have some ideas on how I can work on this and give some examples of flanges and dimensions of tube that is to be used. Some good lessions on this will be appreciated. Thanks do uch for your support./Mike
Reply:You have the exact same post in intro's..See intros....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:^ what he said.-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
GMT+8, 2025-12-30 21:57 , Processed in 0.105380 second(s), 18 queries .
