查看: 13|回复: 0
smallest alumina tigcup ?
发表于 2021-8-31 22:36:31 | 显示全部楼层 |阅读模式
I am designing an extremely tiny electric heating device where I want to pass flowing argon over a filament and shoot out the hot argon out to be used for heating.   I am thinking of using a tiny tig cup (a long nosed extended one maybe)  and I want the smallest one I can get.   I have not seen one smaller than a # 4  ........ is there a #2 or a #1 ???????      I would like a hole in it about 1/8 or less where the gas comes out.How small do they make ?   (cant use pyrex- only alumina )Tim
Reply:If this is not for welding, get some alumina tubing from McMaster-Carr and make an adapter for a standard inert gas fitting that will slip over the alumina tubing. Use the flowmeter or a separate needle valve to control the gas flow.JohnA few weldersA lot of hammersA whole lot of C-clamps
Reply:I was thinking of making a tiny reducer to go on a # 4 tig alumina to reduceit down to a large bore stainless needle like a "canula" used for blood drawing.I am shooting for 1500 degree (F) argon as output-   so I woul dhave to weld the stainless canula somehow ...... (laser weld ?)and adding a needle valve and a tiny flow meter.Tim
GMT+8, 2025-12-30 21:57 , Processed in 0.108527 second(s), 18 queries .
