FCAW-S vs FCAW-G
发表于 2021-8-31 22:36:30 | 显示全部楼层 |阅读模式
Can someone explain why one would choose to use self shielded flux core wire instead of gas shielded flux core and vice versa? I've found a few articles and threads explaining the basic differences in operation but none explaining when either would be more appropriate to use than the other. I honestly don't understand the point of gas shielded flux core. If the "flux" on FCAW-G doesn't actually protect the weld from atmospheric oxidation and needs a shielding gas, why would anyone use it in lieu of solid MIG wire?? Thanks
Reply:I've used self shielded flux core wire in Alaska in 90-MPH winds. Couldn't hardly walk, but could set and weld all day. Try that with gas shielded wire. I'd guess the number one reason for gas shielded flux core wire in the high deposit rate.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:More deposition deeper penetration.Arcon Workhorse 300MSPowcon 400SMTPowcon SM400 x 2Powcon SM3001968 SA200 Redface1978 SA250 DieselMiller Super 32P FeederPre 1927 American 14" High Duty LatheK&T Milwaukee 2H Horizontal MillBryan
Reply:Originally Posted by blawlessMore deposition deeper penetration.
Reply:Most solid wire welding can meet strength requirements but not impact strength.  As more attention is now paid to earthquake codes flux core gas shielded and unshielded can meet these standards.   Long before earthquake standards were a big concern in Northern Canada they paid attention to impact strengths because it was an indication of how a structure would take loads ar sub zero temperatures.  The solution was flux core processes.  I have noticed as the requirement for higher impact strengths have been demanded in warm climates like California the process of choice is flux core.   If you look at the packaging you often see Charpy impact values at a certain temp... - 20 is one temp.  It is interesting compare the stated values between different wires.   Flux cored wires that do not use gas are very smokey.  They are not popular inside a building.  Great for out in the weather :')
Reply:The gas shielded flux core wire is also a bit cleaner.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Originally Posted by lotechmanMost solid wire welding can meet strength requirements but not impact strength.  As more attention is now paid to earthquake codes flux core gas shielded and unshielded can meet these standards.   Long before earthquake standards were a big concern in Northern Canada they paid attention to impact strengths because it was an indication of how a structure would take loads ar sub zero temperatures.  The solution was flux core processes.  I have noticed as the requirement for higher impact strengths have been demanded in warm climates like California the process of choice is flux core.   If you look at the packaging you often see Charpy impact values at a certain temp... - 20 is one temp.  It is interesting compare the stated values between different wires.   Flux cored wires that do not use gas are very smokey.  They are not popular inside a building.  Great for out in the weather :')
Reply:If your in a tuff(critical, requires testing) situation run gas on both if allowed. When running gas on your self shielding make sure its compatible. If your going to use something as 100%, argon. co2 or whatever make some test welds. There are 100s of types of wire and most I haven't used. So read the literature. I've had some self shielding that was crap. Had to be ran with gas. It was Hobart that I bought some time back. I tried that wire in every configuration. Nope, wasted my money. Could have been repackaged? So, I don't want you to waste your cash. I buy all my wire in 30ish# spools. That roll is still on the shelf. Went back to wire and 75/25. Still looking for a place to buy fluxcore that I like. Originally Posted by kestrel452Is that gas shielded flux core or self shielded flux core you're referring to?
Reply:I'm going to put my noob cap back on and ask a stupid question. When exactly are you supposed to use flux core wire instead of solid wire? I get that if you're outside you HAVE to use flux core just for sake of not being able to use a shielding gas, but I've routinely seen people use self shielding flux core indoors (and of course gas shielded flux core indoors). I'm not even sure how to ask this question, but save for the pure necessity of being in an outdoor environment, why/when would flux core wire be necessary? All the literature and videos I've seen do a great job of explaining the operation of flux core wire, but not WHY you would need to use it beyond the whole outdoor thing.
Reply:Increased penetration. Good for welding thick steel. Increased current density over solid wire, more amps per square inch. --Gol'
Reply:@ kestrel452 - View FCAW-G as a deep fusion and heavy deposition rate welding process for multi-position work on thick materials.  Yields a spray-like transfer with minimal spatter.  As 'lotechman' mentioned, the process typically delivers Charpy V-Notch impact toughness tested to -40°F.  Know a dude who fabricates massive bulldozers using 0.052" and 0.0625" outer shield wire.  The welds are pro.  Personally, have only run FCAW-G on 1/4" mild steel in 2F & 3F positions.  Reminds me of a hot version of SMAW with easy:easy slag removal.  FCAW-S is a cheap alternative to solid MIG and, as others have stated, gives deep fusion.  Spattery, but good fusion.From Lincoln Electric,"Gas-shielded, flux-cored electrodes incorporate a double shielding system by using an external shielding gas as well as a slag system. The shielding gas is required to protect the arc and molten metal from the atmosphere. It also results in exceptionally smooth arc characteristics, compared to self-shielded electrodes. They use either a rutile slag system or a basic slag system. The rutile system is the most common and is characterized by a smooth arc with complete slag coverage of the weld. The basic slag system, while producing a globular metal transfer and thinner slag coverage, can be more resistant to weld cold cracking. Most FCAW-G electrodes are ideal for all-position welding and all deliver great mechanical properties with high deposition rates. They are used effectively in general shop fabrication, structural steel (including seismic applications), shipbuilding, offshore, pipeline and other applications.  FCAW electrodes can be used similarly to SMAW electrodes with a few notable benefits in the process itself. First, SMAW electrodes must be fed manually into a weld joint, making only short welds and resulting in a lot of stop and restart areas in the weld.  Restart areas generally have a higher chance of containing a weld defect than any other part of the weld. With the FCAW process, the weld can be made for as long as the welder can comfortably reach before having to stop the arc and reposition themselves. This results in less restart areas in the weld, and ultimately, less chances for weld defects."Last edited by ManoKai; 01-15-2014 at 07:11 AM.Reason: FCAW-S add on"Discovery is to see what everybody else has seen, and to think what nobody else has thought" - Albert Szent-Gyorgyi
Reply:There are a lot more choices with dual shield wire as far different alloys and deposition rates .Miller xmt304,  Miller S22 p12, Miier Maxstar SD, Miller 252 w 30A, Miller super32p12, Lincoln Ranger 9, Thermal Arc 181I with spoolgun, Hypertherm 10000 ,Smith torches. Esab 161lts miniarc.
Reply:Originally Posted by ManoKai@ kestrel452 - View FCAW-G as a deep fusion and heavy deposition rate welding process for multi-position work on thick materials.  Yields a spray-like transfer with minimal spatter.  As 'lotechman' mentioned, the process typically delivers Charpy V-Notch impact toughness tested to -40°F.  Know a dude who fabricates massive bulldozers using 0.052" and 0.0625" outer shield wire.  The welds are pro.  Personally, have only run FCAW-G on 1/4" mild steel in 2F & 3F positions.  Reminds me of a hot version of SMAW with easy:easy slag removal.  FCAW-S is a cheap alternative to solid MIG and, as others have stated, gives deep fusion.  Spattery, but good fusion.
Reply:@ kestrel452 - believe you are correct.  Both self-shielded and gas-shielded flux core electrodes contain de-oxidizing elements (eg. titanium dioxide) within the core to trap/float impurities, resident on the base metal, to the surface via slag.  Check out BLUE's take at http://www.millerwelds.com/resources...ire-selection/ . IIRC, the Cu coating on solid MIG electrodes performs the same de-ox function.Last edited by ManoKai; 01-15-2014 at 08:51 PM.Reason: typo"Discovery is to see what everybody else has seen, and to think what nobody else has thought" - Albert Szent-Gyorgyi
Reply:Gas shielded flux core wire can be used outdoors. We use it outdoors but the wind must be minimal and sometimes we have to set up a wind brake or tarp to help avoid porosity.If the wind is too much for gas shielded flux core process, we brake out the 7018 stick.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Another benefit with the dual shield wire compared to inner shield is that the gas cools the gun so you can avoid buying the special, meaning expensive gun devoted for innershield .Miller xmt304,  Miller S22 p12, Miier Maxstar SD, Miller 252 w 30A, Miller super32p12, Lincoln Ranger 9, Thermal Arc 181I with spoolgun, Hypertherm 10000 ,Smith torches. Esab 161lts miniarc.
Reply:Originally Posted by M J DAnother benefit with the dual shield wire compared to inner shield is that the gas cools the gun so you can avoid buying the special, meaning expensive gun devoted for innershield .
Reply:I do have a question about wire selection.Lincoln's and Hobart's product webpages seem to be devoid of information regarding SP/MP compatibility for gas shielded flux core wire. I was looking at E71T-1 FCAW-G wire since it looks to be the all-purpose type, and came across the Lincoln Outershield 71M which looks like a decent all-purpose wire. Does anyone know if this wire is multi-pass compatible? As fas as self shielding wire is concerned, the literature seems to indicate E71T-11 as being "the" general purpose FCAW-S wire. Are there any applications I should NOT use E71T-11 wire? I'm not going to be building skyscrapers or anything, just home and farm type stuff.
Reply:you can lay down a lot of metal very quickly with the gas shielded flux core, especially in diameters 3/32 and up. the company sent out 1/8" backing bars instead of 1/4" by mistake and i was burning through them like they were made out of tissue paper.i.u.o.e. # 15queens, ny and sunny fla
Reply:@ kestrel452 - "71M" good for all apps and positions, 'cept vertical down.  Grab your turnout gear and a heat shield and run it."Discovery is to see what everybody else has seen, and to think what nobody else has thought" - Albert Szent-Gyorgyi
Reply:We ran hundreds of  tons each of Lincoln Outershield 71M Elite1/16 , co2shielded and Esab Coreshield8 on the World Trade Center along with Lincoln LA-75 /860 flux sub arc too. All have their place
Reply:We welded 8 inch plate with all wires ,over head too.
Reply:Originally Posted by kestrel452As fas as self shielding wire is concerned, the literature seems to indicate E71T-11 as being "the" general purpose FCAW-S wire. Are there any applications I should NOT use E71T-11 wire? I'm not going to be building skyscrapers or anything, just home and farm type stuff.
Reply:Originally Posted by CEPBefore the Northridge earthquake in California Lincoln and Hobart didn't put thickness limitations on their wire. I can't tell you how many 1-inch side bend V-butt plate tests I took with Hobart's 21-B, never failed one. In my opinion for general fab work Lincoln's NR-212 and Hobart's 21-B are hard to beat.
Reply:I have no idea what Lincoln is talking about low alloy.I don't know how true this is, I've had several welding inspectors tell me they have never seen anybody pass a bend test with NR-211. I've run tons of NR-211 but never had to test with it. NR-212 came out after I got out of welding and went into management. I've bought tons of it for jobs, but other than helping someone set their machine I never ran it on the job. I bought a roll of my own for here at home, I like it a lot better than NR-211. Like I side before for general fab work you can't beat NR-212 or 21-B.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400Originally Posted by CEPI have no idea what Lincoln is talking about low alloy.I don't know how true this is, I've had several welding inspectors tell me they have never seen anybody pass a bend test with NR-211. I've run tons of NR-211 but never had to test with it. NR-212 came out after I got out of welding and went into management. I've bought tons of it for jobs, but other than helping someone set their machine I never ran it on the job. I bought a roll of my own for here at home, I like it a lot better than NR-211. Like I side before for general fab work you can't beat NR-212 or 21-B.
Reply:Well here at home I don't run a lot of dual shield, but I've had good luck with ESAB's 710X.First picture is overhead, second picture is vertical up hill with 710X. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Originally Posted by CEPWell here at home I don't run a lot of dual shield, but I've had good luck with ESAB's 710X.First picture is overhead, second picture is vertical up hill with 710X.
Reply:Originally Posted by CEPI have no idea what Lincoln is talking about low alloy.I don't know how true this is, I've had several welding inspectors tell me they have never seen anybody pass a bend test with NR-211. I've run tons of NR-211 but never had to test with it. NR-212 came out after I got out of welding and went into management. I've bought tons of it for jobs, but other than helping someone set their machine I never ran it on the job. I bought a roll of my own for here at home, I like it a lot better than NR-211. Like I side before for general fab work you can't beat NR-212 or 21-B.
Reply:Originally Posted by kestrel452Ah, I was under the impression flux core's only advantage was that it could be used outdoors. So flux core wire also makes a stronger weld overall???
Reply:NR -211 gets brittle in multi pass work  , NR 232/233 are the wires for FEMA low hydrogen structural work and repair work.
Reply:Originally Posted by ManoKai@ kestrel452 - View FCAW-G as a deep fusion and heavy deposition rate welding process for multi-position work on thick materials.  Yields a spray-like transfer with minimal spatter.  As 'lotechman' mentioned, the process typically delivers Charpy V-Notch impact toughness tested to -40°F.  Know a dude who fabricates massive bulldozers using 0.052" and 0.0625" outer shield wire.  The welds are pro.  Personally, have only run FCAW-G on 1/4" mild steel in 2F & 3F positions.  Reminds me of a hot version of SMAW with easy:easy slag removal.  FCAW-S is a cheap alternative to solid MIG and, as others have stated, gives deep fusion.  Spattery, but good fusion.FCAW-S is not simply a cheap alternative to mig.  It does include a cheap alternative such as 71t-11g and gs, but there are other FCAW-S wires that are much more expensive and far greater quality that include qualities far exceeding 7018.  I see FCAW-S and FCAW-G as being equivalent on the mid and upper end of welding with wire as far as strength, dependability, and quality of weld goes.  The only advantage I see the FCAW-G having over FCAW-S is easy clean up due to lower to no splatter.  This is offset by FCAW-S being able to be used in windy conditions.  FCAW-S gets knocked about due to it being used in so many low end machines with the 71t-11g,gs wires.  They have their place and are decent wires, just need to know their limitations.From Lincoln Electric,"Gas-shielded, flux-cored electrodes incorporate a double shielding system by using an external shielding gas as well as a slag system. The shielding gas is required to protect the arc and molten metal from the atmosphere. It also results in exceptionally smooth arc characteristics, compared to self-shielded electrodes. They use either a rutile slag system or a basic slag system. The rutile system is the most common and is characterized by a smooth arc with complete slag coverage of the weld. The basic slag system, while producing a globular metal transfer and thinner slag coverage, can be more resistant to weld cold cracking. Most FCAW-G electrodes are ideal for all-position welding and all deliver great mechanical properties with high deposition rates. They are used effectively in general shop fabrication, structural steel (including seismic applications), shipbuilding, offshore, pipeline and other applications.  FCAW electrodes can be used similarly to SMAW electrodes with a few notable benefits in the process itself. First, SMAW electrodes must be fed manually into a weld joint, making only short welds and resulting in a lot of stop and restart areas in the weld.  Restart areas generally have a higher chance of containing a weld defect than any other part of the weld. With the FCAW process, the weld can be made for as long as the welder can comfortably reach before having to stop the arc and reposition themselves. This results in less restart areas in the weld, and ultimately, less chances for weld defects."
Reply:Not to cloud this issue too much, but I run flux core pretty much exclusively in my Lincoln SP-135P (115 volt wire feeder) even though I have a gas bottle.  Welder is more portable that way, more oomph with the flux core too, and I weld exclusively outdoors.Anyway, I run Hobart Fabshield 21B (E71T-11) as it is suitable for multiple passes where Hobart's Fabshield 23 (E71T-GS) is NOT suitable for multiple passes (do the research yourself if you do not believe me).  I imagine the same holds similar for the Lincoln versions too as another mentioned how brittle it gets with multiple passes.  I do not burn the Lincoln's in my case as it is harder and more expensive for me to obtain so I have not actually researched it.  I also like Hobarts 2lb spools much more so than Lincoln's 1 lb spool size when buying little spools.   I have run many E71T-GS before I new the difference and I never liked E71T-GS when I had to make multiple passes.  Once I figured things out I definitely like E71T-11 much better for my uses.  Granted the E71T-GS is earthquake rated where the E71T-11 is not earthquake rated, but the E71T-GS getting brittle with multiple passes in not good either for a backyard welder using a 115 volt wire feed unit where you have to make multiple passes on thicker stuff due to small machine size.  All I know is E71T-11 will continue to always be in my welder where I will never ever buy E71T-GS again.  I have even had good luck repairing some cast irons with E71T-11.  All in all I am a huge fan of Hobart Fabshield 21B (E71T-11).Last edited by rankrank1; 01-18-2014 at 03:14 PM.
Reply:@ ScottYoung - the "cheap" in my above post was aimed at a comparison with GMAW, not FCAW-G, in the context of financial.  However, MIG and FCAW-G are closely matched in the total cost of doing business.  We'll proceed. Understand there are high-dollar flux core wires used in industry, especially with pipeliners.  While there are FCAW-S electrodes that are more expensive relative to solid wires, welding with self-shielded flux core electrodes does not require a compressed gas cylinder, shielding gas, regulator, hose, etc.   A thought.  Welder A runs FCAW-S with the "expensive" electrode.  Welder B uses FCAW-G with a wire of equal high-strength mechanical properties.  Forget the environment, etc.  Hourly cost of operation for Welder A is lower than Welder B.    In fact, Miller states running flux-core versus SMAW on a particular job, saved a company 30%:http://www.millerwelds.com/resources...k-welding-smaw.  Read the final paragraph.Apples to apples.  FCAW-S is a financially cheaper alternative to FCAW-G and MIG."Discovery is to see what everybody else has seen, and to think what nobody else has thought" - Albert Szent-Gyorgyi
Reply:Originally Posted by PavinsteelmanWe ran hundreds of  tons each of Lincoln Outershield 71M Elite1/16 , co2shielded and Esab Coreshield8 on the World Trade Center along with Lincoln LA-75 /860 flux sub arc too. All have their place
Reply:Originally Posted by Scott YoungWhy don't you weld a couple coupons and bend them?  if anyone could do it you could.
Reply:I may be wrong, but the 211 mp is 71t-11.  If memory serves me right, all 71t-11 which includes lincoln's 211mp is thickness limited and three pass limited.  each pass much contain base/parent metal.  The single pass version are 71t-11g & gs.Since 71t-11 is the wire in question, nr211mp will do nicely.
Reply:OK, well we'll see what I got, hopefully it's not to old? I think I have some 1/2-inch thick coupons cut already.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:@ CEP - how'd you like the ESAB 710X?  Your 3G image looks money!  Have only used Lincoln Ultracore to date.  A good buddy of mine gifted me a 33# roll of ESAB 710X-M in 0.045.  Need to fill up on C25 before testing her out on some 1/4" mild steel."Discovery is to see what everybody else has seen, and to think what nobody else has thought" - Albert Szent-Gyorgyi
Reply:I really like it! Childs play to run. I've run a lot of other brands, but can't remember the names. Because that was the 1970s or early 1980s.Well, I have 3 or 4 rolls of NR-211, but I gave my pie pans away! So I have no way to load the 14-pound coils in the LN-25! Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:I have run many miles of esab's 7100 ultra and it is the cat's meow.Yep, that is the stuff right there CEP.  I have run bunch of it of it, but not much as I have on HB21B.  I love Hobart Brother's wire.  I haven't found any I dislike.  The only difficulty is finding it or having the shop carry it.  I have a closet with several spools of wire like your cabinet.  I probably won't need to run out and get any wire for a while now that I am no longer welding professionally.
Reply:It took me a little bit this morning to remember what I'd done with my pie pans. Last spring I got a buddy of mine set up with his first LN-25. Years before I gave him an old LN-22 I had, he bought several 14-pound coils of wire for his LN-22. When he got the LN-25 I gave him my pie pans so he could run his 14-pound coils in the LN-25. I thought those days of running 14-pound coils were over for me, so why did I need the pie pans!http://www.lincolnelectric.com/en-us...x?product=K435Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:not trying to say you can't or anything, but I just thought I'd mention it:if your bend tests fail, it might be because the wire is old enough to have picked up some moisture.you might see the difference because porosity is round, and stress cracking is, well, a crack with sharp points. halfway the bend test, in the very beginning of the crack growing, you might distinguish between both.
Reply:I have a set here, but that doesn't do you any good. LOL  I have a couple rolls that need them.  Just a thought, on one of the sub arcs we used we had a scrap made adapter.  it would be cheaper and quicker for you to tack an adaptor together for yourself than it would be to buy a new set.I realize that the adapter was for a different sort of wire and process, but the concept is the same.  it is easy enough to cobble something together than to drop the coin on a new adapter.Last edited by Scott Young; 01-19-2014 at 01:46 PM.
Reply:I made some of those adapters using the wire spools that are made out of 1-8 inch wire with the hole in it. Cut the outer ribs that hold the 2 pieces together, bend the wires out, center your new spool inside, bend wire back down then tack pieces across to hold together. Another way is you take an old wood wire spool ,cut 1 side out so the Redi Reel slides over, cut 3or 4 wood spacers and drywall screw them from the outside to center the spool. Either run suitcase on its side or make up a tab you can screw to the side of the reel to hold the coil on .Miller xmt304,  Miller S22 p12, Miier Maxstar SD, Miller 252 w 30A, Miller super32p12, Lincoln Ranger 9, Thermal Arc 181I with spoolgun, Hypertherm 10000 ,Smith torches. Esab 161lts miniarc.
Reply:This question probably overlaps a previous one that I've asked, but if I am going to be welding something like a car frame or heavy machinery, is it important that I use FCAW-G wire instead of solid core for weld strength's sake? I just bought some Hobart .035 solid core wire and I was wondering if I should avoid using it for such strength-reliant welding applications and use some Outershield 71M.
Reply:I don't remember all the details, my brother-n-law has been a body & fender man for decades. He was telling me some car manufactures require Mig welding only on their frames.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Originally Posted by kestrel452This question probably overlaps a previous one that I've asked, but if I am going to be welding something like a car frame or heavy machinery, is it important that I use FCAW-G wire instead of solid core for weld strength's sake? I just bought some Hobart .035 solid core wire and I was wondering if I should avoid using it for such strength-reliant welding applications and use some Outershield 71M.
Reply:Originally Posted by CEPI don't remember all the details, my brother-n-law has been a body & fender man for decades. He was telling me some car manufactures require Mig welding only on their frames.
GMT+8, 2025-12-30 21:48 , Processed in 0.108591 second(s), 18 queries .
