Another smoker build
发表于 2021-8-31 22:36:29 | 显示全部楼层 |阅读模式
I have built 6 smokers now this one being the largest, my dad wanted to out do the last one I built for him and here is what we ended up with. started out with 3 sheets of 1/4" plate the rest we had around the shop. Smoker racks are stainless expanded metal, look flimsy but I threw a 45lb box of fluxcore wire on one and It didn't sag a bit, grill side had heavy expanded metal for the fire grate and bar grating for the cooking surface. I also made the damper between the fire box and smoke chamber adjustable. Its way overkill but my dad says it works great and has filled it up. Attached Images
Reply:more pics Attached Images
Reply:Painted, He is a big OSU fan and we had that brass cut out left after doing some work that went into their football arena. Attached Images
GMT+8, 2025-12-30 21:57 , Processed in 0.077267 second(s), 18 queries .
