Pickin up my new Power MIG 255
发表于 2021-8-31 22:36:24 | 显示全部楼层 |阅读模式
Does anyone know what size spools of wire they are setup to run from the factory, I know there are adaptors for the bigger spools, but im hoping I can at least run a 2lb or 8lb spool out of the box?Thanks,Jim
Reply:I am running a 40lb spool in mine -- no adapters.
Reply:First of all, congratulation. I think you made a wise choice going with the PM 255 over the PM 215. To answer your question, it looks like from the factory the machine is set up to run an .035 or .045 wire off a 12" spool. To run an 8" spool you will need to purchase this adapter.http://www.mylincolnelectric.com/Cat...eet.asp?p=2197
Reply:Jim,Good luck with it and have fun!. Let us know how you like it.
Reply:Thanks for all the help guys, got the welder on Thursday, didnt have much time to use it untill this weekend.  I am very happy with it, the quality is amazing, its very easy to use, and it lays down killer welds.  Awesome product!  I have some pics if anyone cares, go here:http://www.mckeone.net/photos/welder/powermig/Jimwww.jmfabrications.comLincoln Precision TIG 375Lincoln Precision TIG 275Lincoln Power MIG 255Lincoln Power MIG 140CMiller Dynasty 350 (x2)TD Cutmaster 80
Reply:Looks great.   I have just ordered the Millermatic 251, should be in next week. I am a new member and am new to welding. i have been taking a weldind coarse for the last 3 weeks and have one more week to go. I found this site one night surfing, and am looking forward to reading all the info .
GMT+8, 2025-12-30 20:05 , Processed in 0.115062 second(s), 18 queries .
