Lincoln MIG Pak 15 welder have fitting for gas?
发表于 2021-8-31 22:36:24 | 显示全部楼层 |阅读模式
My local Canadian Tire store has this welder on sale $600 ca and it doesn't come with gas valves. Is there a fitting on the back to instal one? I plan on using it for steel and aluminum. How good would it be at welding aluminum? I have been doing some reading on the Lincoln web site and was wondering if this welder is similar to the Lincoln Electric SP-175. I am new to welding so any feed back is welcome
Reply:There is a gas line fitting on the back for your regulated gas pressure. Only used mine on steel so far.PowerMig 255cCutmaster 51Powermax 1000 (for cnc table)Precision TIG 185 for salePrecision TIG 225
GMT+8, 2025-12-30 20:04 , Processed in 0.074309 second(s), 18 queries .
