sp-135 plus help
发表于 2021-8-31 22:36:23 | 显示全部楼层 |阅读模式
Just picked up a used lincoln mig. Guy said if It didn't work could return it to him. I purchased some .030 flux cored, set everything up, turned on the welder, pushed the trigger and nothing. I have used the sp 135 before so I am fairly certain that I have evrything dialed in right. Any ideas on what could be going on. Wire does spool out of the gun. When I push the trigger and I strike the wire on the metal, I do get a tiny spark but other than that nothing.
Reply:dunno! bad ground!does the wire still spool up while touching to work?i would say polarity but an arc would still be established!as i said first.......dunno!best of luck and post what you found out!  i don't have a spunky username just what it is, me!
GMT+8, 2025-12-30 21:57 , Processed in 0.165594 second(s), 18 queries .
