flap discs - resurfacing the leading edge
发表于 2021-8-31 22:36:21 | 显示全部楼层 |阅读模式
Is there a trick for bringing back to life a flap disc? I have some 80 grit wheels that are not cutting well but there is lots of great sand paper in there about 1/16" of an inch back from the worn edge. I'll try to take a photo.
Reply:I have seen a "do not trim past this line" on some flap discs.  I have often wondered what to trim them with and still keep them round.  I also look forward to the replies.Syncrowave 210HH140Victor O/A
Reply:Turn it sideways with it running and trim it back on the edge of your bench grinder wheel while that is running as well.I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Jimmy_popTake your pick . . .http://www.google.com/search?client=...kQsAQ&tbm=ischOpus
Reply:Heres a pic of what i was saying. Both grinders running and ZIP, youre done in two seconds.I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:If you take the wheel to the square cut edge of a piece of flat or angle you can accomplish the same thing. Works best on the plastic backed wheels such as Walther.
Reply:Walther is a gun.
Reply:I use an old file in a vice or the square edge of a table ....Mike
GMT+8, 2025-12-30 21:53 , Processed in 0.143139 second(s), 18 queries .
